Engine Start Button
#381
Cody, I have the Ford Racing one and it doesn't illuminate....
#383
Nope, it looks great but no illumination but I guess it would not until you turn the key on when the instrumentation lights up.. Don't know how the others work as I would not need it lit up when the car is running.
#384
Anyone here as used an alternate location to install the "Start" button ?
I would like to keep my power outlet for my GPS and I'd like to install the button as well. I was thing to put it on the flap at the left side of the radio, anyone done it ?
#385
I relocated the power port right next to the other one in the console so I would not lose it. It works great and they are side by side....
#386
@all with "oil pressure warning":
your engine start button is wired wrong
the ignition switch has 3 positions:
1 Run/Acc
2 Run/Start
3 Start
if you turn your key in position 2 and want to start the car, all accessory devices (like radio, front lights...) are turned off, to provide maximum power for the starter.
if you just bypass the dark green wire to start the car, the accessory devices are not turned off and the enormous power consumption of the starter is maybe "confusing" some sensors like the oil pressure sensor.
so if you want to start the car by a starter button you have to "emulate" the ignition switch.
its very simple. if you push the button you have to interrupt power to accessory devices and provide power to the starter.
this can be done with relays.
How to:
find connector 250 to the ignition switch on the left side under the steering wheel.
cut the black/pink and the green wire.
wire everything as shown in the circuit diagram.
ps: if you still want to start the car with the key, don't cut the green wire.
1 Run/Acc
2 Run/Start
3 Start
How to:
Anyone knows how much current flows through the Ignition normally ?
#389
Hello everyone, needing help out here if possible
I wired my S2000 button wrong i think.. I connected, green wire from the ignition to the first pin, and then for the second and third pin i conected to the 12v source of the lighter.. didnt work.. so reading all this thread, i guess first pin for the green wire, second pin for the white wire at ignition, and third for ground. It's this way?
Best regards
Oh, mine it's a 06 GT
Best regards
#390
C'mon guys help me pls.. now i have done some **** to the car... accidentaly i touched the green and the withe wire.. now when i turn the key the car dont turn on the lights and it«s just beeping inside.. can anyone tell me how to solve this one? just want to get the car started and then ill go to a shop for they can install my starter button.. dont knw what went wrong.. plugged the first pin to the green wire, the second pin to the white wire on the same plug where the green wire is, but on the opposite side, and the third pin conected to the ground..
Again help me here please
and thnz in advance.. the repeatble beep beep might be an alarm thing no? :S any way to unlock it?
#391
Sorry Fabio, i= I used the Ford Racing Plug and Play button. Can you place everything back together and reset system by dis connecting the battery?
#393
Hey Dave and Javier, thanks for the replys mates. It was the ignition fuse that blowed up, replaced and it's ok now. Monday, i will take the the car to the shop so they can see what's the best way to install the button cause i cant figure what went wrong :|.. again ty guys, almost got an heart attack with that thing :/
#394
Glad you got her started!
#396
I lust for a M24
Fabio - I'm babysitting a 5 year old, two 1 year olds, and a 3 month old baby right now... let me review this when I can think straight and we'll get you figured out.
#397
thanks guys
, dont bother John, ty very much for the reply
) tomorrow ill take the pony to an electricist so he can see what are the correct wires or something, cause i cant solve this one :S
#399
Nice!
#400
It is time to make that Honda S2000 start button into a true keyless ignition:
http://www.digitalguarddawg.com/auto...-luxury-series
I am looking into this for my 05 that already has the start button, but I messed up with the struts in my 12, so it may wait until the new year.
I like that they sell the S2000 button with an LED in it to make it brighter. I had to remove the diffuser in mine to get that effect.
It adds keyless entry and trunk release (no pressing a button on the FOB for either) and security alarm as well as remote start.
The only thing I don't like is the FOB, but I can live with that. This will be my Christmas present to me.
