Engine Start Button
Old 1/19/08, 08:09 AM
  #281
I lust for a M24
05GT-O.C.D.'s Avatar
Better?
Old 1/19/08, 11:26 AM
  #282
NYNY53's Avatar
Originally Posted by 05GT-O.C.D.
Better?
Ahhh much better
Old 2/11/08, 01:53 PM
  #283
2kanchoo's Avatar
I have this same kit. I laughed so hard when I saw it I just had to go out and get it. I also installed it myself. Interestingly enough it is out of a honda s2000. If you look close before install you can see honda stamped on the part. I just happened to check out a 06 s2000 a couple days before this kit showed up and I recognized it. I guess a little "rice" never hurt anyone.
Old 2/13/08, 03:28 PM
  #284
S197 V6's Avatar
Originally Posted by 07tungstengreyGT
i ordered it online from pep boys. really cheap it was like $40 shipped and its really easy to install an they have green, red, yellow blue and i think another color but i cant remember.
I really like the one youve got here. What else did you need to buy to install it since it doesnt come with the wiring harness, and where did you get these parts from? Thanks!
Old 2/13/08, 05:18 PM
  #285
I lust for a M24
That's the same one I used. The only other parts needed are wire which you can get anywhere... I used scraps from other projects, and a relay if you choose. I didn't use a relay as I don't feel it's necessary, and I haven't had any problems.
Old 2/13/08, 07:56 PM
  #286
S197 V6's Avatar
Ive never done anything like this before, and I have no experience with wiring and stuff like that. Is there anyway you could tell me exactly what I will need to make it work. Sorry, but I am an idiot when it comes to this sort of stuff and prefer to have everything I need and not need to improvise but just follow step by step instructions to make sure I dont mess anything up.
Old 2/13/08, 08:39 PM
  #287
I lust for a M24
Really, the only things you need are the proper tools including wire strippers and regular hand tools, plus either a file or dremel to open up the powerport just slightly. Other than that, just some wire, (I always try to use a similar gauge (thickness) wire to what wire I'm tapping in to), and whatever you want to make your connections with (electrical tape, or crimp connectors, etc). I like electrical tape for interior projects like this, but that's just my preference because it's easy to work with and make sure your connections are solid.
I'm not a pro though, just lots of experience from tinkering and a little guts to try something out.
I see you're in PA, how far from Canton OH?
Old 2/19/08, 09:59 PM
  #288
jacostang's Avatar
Did mine today, love it! I relocated the power port right next to the other one in the consol...
Old 2/24/08, 11:53 AM
  #289
bacnblak's Avatar
Here's how I wired my S2000 start button:
Pin 1 (far right on S2000 connector) to dark green wire behind ignition switch.
Pin 2 (2nd from right) to white wire behind ignition switch.
Pin 3 (3rd from right) to ground.
I used a six pin connector/cable I had in my computer parts box and removed three of the pins. It fits really good.
There are no issues when the button is pressed with the engine running.
Old 3/2/08, 11:43 AM
  #290
Snaky's Avatar
I went over all 15 pages but couldn't find a clear answer for the question: Is there a solution how we can fix the "low oil pressure" warning? I really hate this message all the time.
Thx
Thomas
Old 3/2/08, 11:59 AM
  #291
red454's Avatar
I have to wonder if the low oil message is really related to the start switch. If you pull power from the ignition switch (so the start button only has power when the ignition is on) then that may take care of the problem.
If you pull power from the cig. lighter, that may be the problem...
Old 3/2/08, 10:18 PM
  #292
jim010's Avatar
The problem is only there if you delay in starting the car after you turn the key to "on". It would be no different if you turned the key to "on" and waited before you turned the key the rest of the way to start the car. It is not an issue.
Cheers
Old 3/3/08, 06:57 AM
  #293
omendez's Avatar
I posted a question about this Low oil pressure message back in 07, befor i realized that it was because of the push button ignition, I just stoped using it cause it drives me crazy, so if someone can come up with a solution that would be great.
Old 3/3/08, 01:50 PM
  #294
n8rfastback's Avatar
i havent even heard of this issue with the push button start until i just read these posts....
weird
Old 3/3/08, 01:54 PM
  #295
jacostang's Avatar
weird
Is it with the S2000 Button? I have no issues with the Ford GT one.
Old 3/6/08, 09:36 AM
  #296
Snaky's Avatar
Yes, it is the S2000 button
Old 3/6/08, 06:32 PM
  #297
jeffgall's Avatar
I really want to do this mod but can't decide which button to get, the 50resto one or the ford racing one out of the GT. What color do they light up in at night? I assume the lights only come on at night?
Old 3/6/08, 07:00 PM
  #298
jim010's Avatar
The 50resto (Honda) lights up red, and is always lit up when the power is on. I think the Ford GT doesn't light up?
Cheers
Old 3/6/08, 07:07 PM
  #299
jeffgall's Avatar
Is it red or amber. An orange color would turn me off. Also, does anyone have the instructions that come with the 50resto kit?
Old 3/6/08, 07:21 PM
  #300
i like how my honda one stays lit all the time, you really cant tell unless its dark out, then it just looks cool and blends right in with the other gauges and stuff
Quick Reply: Engine Start Button
