JLT Intake Kit Installed
#141
Originally posted by 2005RedGT@March 19, 2005, 12:48 PM
Hi, Blk05GT. I will pics for the info in just a min.
-Bryan
-Bryan
I noticed you had updated information about the fix. Let's all hope that this will fix it for good - we'll know in a few days
#142
Brian, I hope this works. Let us know.
I just called you, when you get a chance give me a call.
Jay
GUYS: I must say I apologize for this issue and I WILL get you all straight. I never had it happen and know all the sudden we got problems. Please don't lose faith, we'll get it fixed.
Jay
One thing I think it causing the insert to not seal is it pulling up that slight bit at the start of the tighten process. If it were glued in or held down some how as the screw is tightened it should tighten good and seal. Just a thought. Brain storming.
Jay
Jay
#143
A small amount of contact cement on the insert holes and let it dry for a few hours should work well. When I removed my MAF today it pulled right out and I had it snug. I was looking at it and the first thing that came to mind was glue. I think that is the fix, simple enough!
#144
I spoke to Jay on the phone for a while. He is very adamant in getting this resolved and making sure that his current customers are satisfied as well as assuring that his future customer will be secure in knowing this. I belive him and look forward to his solution.
-Bryan
-Bryan
#145
-Bryan
-Bryan
Jay really is diligent in trying to make this right by us...be patient, a good solution will be found!
#146
I will ty a few diffeent ideas and let you all know what's the best fix.
As Bryan said, I am commited to this product and finding a easy fix. This is a learning experiance and products all ways need updating.
one thing for you to try is this:
Slowly tighten one screw then the other. Trying not to allow the insert to pull up. Slowly doing the back and forth method the inserts should do there job and tighten and seal.
Let me know
Jay
#149
Originally posted by swingle007@March 19, 2005, 7:28 PM
Be glad when mine shows so I can see what all the talk is about....LOL
Crossing my fingers for a Monday delivery!!
John
John
It's all blurring together right about now. :scratch:
#150
John
John
Swingle007, You mean that car is going to be even faster! How am I ever going to keep up? You are going to love this intake.
#151
I just redid mine a couple hours ago with the new method...maybe a quarter turn each - back and forth. Seemed to give me a lot more "bite" when tightening it.
I also tried out the new tune from DTP...the pinging seems to be better/gone (need the pavement to dry up a little more before I give it the thumbs up). I have an email back to Brent at DTP asking what was changed on the new file.
#152
The Home Depot near my house didn't have the right size expansion nuts (worst store ever) so I bought new well nuts since the old ones slipped out very easily. (I think I tried to tighten them down too much)
The new well nuts are a little bigger than the originals but I believe I got it torqued down better than I had before. Going back and forth between the two screws definitely helped get it tight. I will reflash and hope I finally got it. A lot of good tips in this thread. Thanks for the help.
#153
Got mine today afterall ....Didn't realize it as I checked my mail late...Wife works at the office of the apts. we live at so she went in a bit ago and grabbed it for me out of the mailroom. Looks sweet! IF the weather holds up I'll try and put it on tomorrow sometime.....Here's a pic or two I just took on my coffee table....
John
John
#154
I don't have mine yet(waiting for the Predator tune), but would a rivet (probably aluminum) work? Possibly cut a slit near each hole and use a J or U nut? Maybe I should just order mine and do a little 2MFF Fabrication on it.
#155
Jay
#156
Went to home depot this morning and purchased the new compression nuts and used the rubber cement and secured them in place. This should do the trick.
Jay, please keep in touch with DTP on the Diablo tune on CD. I need this....
#157
Yup me too. That JLT is looking fast just sitting there in my garage. I can't wait to put it on. I need that tune. I'm going to run to Home Depot today then I'll be ready and waiting.
Jay
Jay
#158
Originally posted by The Boss Hog+March 19, 2005, 10:42 AM--><div class='quotetop'>QUOTE(The Boss Hog @ March 19, 2005, 10:42 AM)</div><div class='quotemain'><!--QuoteBegin-HOTLAP@March 19, 2005, 12:12 PM
When I installed my JLT - I used nuts/bolts to better secure the MAF sensor and ran a bead of silicone gasket maker around the MAF's rubber gasket - just to make certain no air could get past the mounting area and that the MAF Sensor was nice and secure. I also ground down the nuts (on the inside) using a dremel - so they wouldn't interfere with airflow and cut down the inside of the hose mounting "nipple" (at the other end of the intake) so as to be less restrictive to air flow.
I would exersize extreme caution when using this fix. You have now introduced into your intake stream, a piece of metal (the nut) that has the potencial over time to vibrate loose and be eaten by the engine. I would be very nervous if it were mine.
The Boss Hog
[/b][/quote]
Good point - if I would have been thinking when I did this I would have turned the nut/bolt around so the head is on the inside. I just went a rechecked and the bolts are still tight - they do "dig in" to the plastic inside surface pretty good - so should be OK - but out of caution I do think I'll turn them around.
#159
Originally posted by 2005RedGT@March 19, 2005, 10:28 AM
HOTLAP, and CEL's at all ?
-Bryan
-Bryan
Bryan - just one CEL episode when I installed the Steeda UD pullies.....I had taken off the CAI for access though and perhaps that's how I tripped it? All runs fine and I fixed it by disconnecting the batt for a while....hasn't come back in a couple of weeks so - I'm assuming everything is OK with it.
Thanks for your reseach/fix of the MAF mounting - I'm going to check out your web site now.
