2005/2006 Mustang Squeeking Brakes
Old Aug 16, 2005 | 07:40 PM
  #101
Ripstang's Avatar
legacy Tms Member
You can see Dan from my posts I didn't get 2 months untill it came back but its the rear that are acting up ,the front seem good .If this doesnt work ( new ford pads ) I'm going to try the Wagner disk Quiet ceramic pads for the 05 mustang ,they already make them for the car and I have a few friends that have them on the front disks of there trucks when they first came out ...no noise at all and no black brake soot just a fine white dust and thats it .
And if I do go to the Wagner it will be all the way around just to be on the safe side.But I do prefer Ford to fix and take care of this ....If you look at the polls it now getting closer to 50% having this problem .
Old Aug 16, 2005 | 09:40 PM
  #102
dekujala's Avatar
Can I change my vote? My brakes are now squeaking at about 4500 miles. Sounds like its the driver rear.
only does it when light braking
Old Aug 16, 2005 | 11:55 PM
  #103
Dan's Avatar
Dan
Do You Remember Me?
Yes, as I've read. I half expect it to come back but a guy can always hope
Let me know what happens after you take either route.
Old Aug 17, 2005 | 07:42 AM
  #104
pony_up's Avatar
Will the "bedding in" procedure work on a car that has over 5K miles on it? Our V6 started squealing at around 3K and it's getting worse.
Old Aug 17, 2005 | 12:24 PM
  #105
Radman's Avatar
Try the bed-in procedure!!!! It worked great for me after a second set of pads from Ford. 10-12k miles later and not a squeak to be heard. Do the bed-in procedure before you do anything else, especially if it involves money.
Jason
Old Aug 17, 2005 | 04:55 PM
  #106
Ripstang's Avatar
legacy Tms Member
No problem I will keep everyone posted on how this turns out,but when I get the new shoes I will bed them again .
Old Aug 29, 2005 | 10:43 AM
  #107
Ripstang's Avatar
legacy Tms Member
The new shoes are on and I also had the strut pop so that was taken care of at the same time .
The new pad numbers are for new shoes for the mustang for the rear from what my service manager told me they called the ford service tec hotline and thats what they told them.
They also asked about chamfering the pads just in case and they said no they will be fine just put them on and drive it ..so i will skip the bed in process for the rears and see how it goes but from the feel of it I belive this will work ....no sqeek or noise at all whether i press hard/med or soft on the brakes .And no strut pop
Thanks again everyone for all your help I couldn't have gotten this fixed without you :worship: ^_^
Old Aug 29, 2005 | 12:21 PM
  #108
GhostGT's Avatar
Never had any squeaking...which Im really happy about, considering the amount of people here who say their brakes DO squeak.
One thing that kinda sucked, though, was that my street just got "recemented," or as I would call it, "Glued cheap little pebbles onto old cement."
A few times while I was driving, those little pebbles would get stuck between my disks and break pads, and WOW, this AWEFUL screeching noise would come out of under the car, almost like when chalk rubs against the chalkboard the wrong way .
Anyway, I've checked my brakes, and there are very faint, but still visible, lines across my pads. STILL no problems, though.
Old Sep 16, 2005 | 05:01 PM
  #109
Ripstang's Avatar
legacy Tms Member
New TSB for rear brakes and I belive Dan has put it up In the TSB section with the new part number the same that kevin gave me :worship:
Old Sep 16, 2005 | 05:04 PM
  #110
Ripstang's Avatar
legacy Tms Member
http://www.bradbarnett.net/mustangs/galaxi...rake_squeek.pdf
TSB for rear brakes ..thanks guys!!
Old Sep 17, 2005 | 09:56 AM
  #111
05stangkc's Avatar
It's Amazing That Part Number has been out for 6 months and Ford just now releases a TSB. AMAZING.
Old Oct 6, 2005 | 09:20 AM
  #112
05stangkc's Avatar
I have Updated this Poll for the 2006 Mustang Please Participate. Please allow 3000 Miles before Responding that they do not Squeek!
kc
Old Oct 6, 2005 | 08:30 PM
  #113
davids2toys's Avatar
3500 miles never squeaked at all, but I bedded them in at the 500 mile mark
Old Oct 22, 2005 | 05:16 AM
  #114
05stangkc's Avatar
No 06 Squeekers?
Old Jan 20, 2006 | 10:22 PM
  #115
05stangkc's Avatar
FYI,
If you have the Squeeking Brake Concern it is only covered for 12 mo 12,000 miles as far as the TSB Brake Pads are concerned.
Old Jan 21, 2006 | 01:09 PM
  #116
RPM's Avatar
RPM
No squeekink here with my '06 yet. Would WD40 be a good fix, you know their slogan: "if it sticks or squeeks".
Old Jan 21, 2006 | 01:13 PM
  #117
70MACH1OWNER's Avatar
:nono: :nono: :nono: :nono:
Old Feb 17, 2006 | 11:48 AM
  #118
recon06's Avatar
<div class='quotetop'>QUOTE(05stangkc @ October 22, 2005, 5:19 AM) Quoted post</div><div class='quotemain'>
No 06 Squeekers?
[/b][/quote]
As an ASE Mechanic and worked for differnt type dealerships, the most common correction wich works most of the time I have experianced is to wash out the caliper when washing your car or use brake cleaner to get the dirt, dust, ect... out between the rotor or pads, also you should check to see if your pads are loose. replacing pads and turning rotors is last case resolve.Have done it on all of my cars, including my 05 stang no problems
jonztang
Mar 25, 2015 10:40 PM
Noilly Pratt
'10-14 Interior and Audio
Nov 12, 2014 11:34 PM
Norberd
Oct 8, 2011 06:40 PM
manashttu
Jan 31, 2011 06:02 PM
OKLACOP
Jan 19, 2006 05:47 PM
