2005/2006 Mustang Squeeking Brakes
Originally posted by Radman@January 13, 2005, 2:35 PM
Squeaking here. Dealer turned the rotors and replaced the brake pads once. Squeal went away for about 1k and then came back with a vengeance. I take it in tomorrow am again so they can look at it for the day. If the squeal comes back after whatever 2nd fix they try, I'll probably buy some new brake pads and try those before I take it in for a third time. I do not believe that this is normal behavior, otherwise we'd all be suffering from it. This is a problem, albeit a minor and embarrassing one, and should be resolved. I'm confident that it will be resolved.
Jason
Jason
Originally posted by 05stangkc@January 14, 2005, 11:27 PM
I think 36% is a pretty good indication that something is not right!
KC
KC
As for turning the rotors, I could care less as I will be replacing them anyways.
Jason
I just bought my first Mustang (I previously stuck with GM) and was noticing squeeking brakes. I was hoping they just needed to be broken in, but it sounds like it's not going to go away. It happens for me when lightly braking.
Sqeeking the day I bought the car, last Saturday. The saleslady told me if it persist to let them know and they will take care of it. I noticed too when I gave her a bath Friday afternoon that there is some rust on the rotors of the front brakes. Should I be concerned? No other problems to note.
And Man I Love My MUSTANG!
Mine squell a LITTLE bit, and it's sort of random. I think it might just be dust getting in my breaks because after I wash my car it generally stops. It's not a long drawn out squeal either, it just does it when I first put my foot on the break for 1 second then stops.
Like another poster mentioned mine is generally under light breaking only.
I noticed a v6 car I drove the other day had the exact same Squeek! My Gt is Squeeking again also! The only time it seems to go away is after my wife drives it! She drives like she is in Nascar!
kc
kc
mine didnt squeel until they changed my wheels to the bullitts
they have ever since then
in the people that have squeeling brakes, have your wheels been off?
maybe there is something about the rotors warping with incorrect torque, or sequence??
im going to take mine off and put them on the lathe this weekend to see what i come up with
I got tired of waiting for a Brake fix from FORD so I took matters into my own hands today! Now before anybody says Ford should fix this I AGREE. But I am tired of having people check out my car only to be embarrassed by the brake squeel. Ford has released a new Part number for rear pads so I figured maybe thats where the problem was. But sometimes a new part number is because of a price or vendor change. Also Both the v6 and v8 use the same rear pads and I drove a v6 that had the same squeek it seemed the logical place to start. Anyway I removed the rear pads and they looked great so I applied some of this BG Products stop squeel and hoped for the best. After a short drive the squeel was still there so time to do the fronts. The front Pads were smooth in the center but rough around the edges. Sharp as a matter of fact!. So I took a small sanding roll and chamferred all the sharp edges including the slit down the center. I then soaked them with the BG Product and let them set for 20 minutes. After reinstall and a Long test drive the squeek is GONE. But only time will tell if it returns. I will update as mileage accumulates! But for now the Mouse is Gone!!!!!!!!!!!!!
https://www.bgprod.com/catalog/brakes/bg-stop-squeal/
kc
kc
