2005/2006 Mustang Squeeking Brakes
Old Jun 15, 2005 | 12:00 AM
  #81
hughes200's Avatar
I just hit 3000 miles on my 05. The breaks started squeeking. The dealer says that don't see a problem. Does anyone have a TSB on the brakes?
Old Jun 15, 2005 | 12:02 AM
  #82
Jeffs05GT's Avatar
I had a squeak on my car, the dealership looked at it when they replaced the gas tank and did the front strut fix and said there was some glaze on the rear brakes and buffed it off. Squeak was gone but is now coming back, perhaps something with our braking system is causing brakes to glaze creating a squeak, and when people do the bed-in method it temporarily removes it until the glaze comes back? Would this mean our brake pads just stink hiney?
Old Jun 15, 2005 | 08:19 AM
  #83
DeathMonk's Avatar
My brakes only squeak when they are heated and while turning the wheel far to the left of right.
Old Jun 19, 2005 | 10:33 AM
  #84
Ripstang's Avatar
legacy Tms Member
Ok had the brakes done at the dealer ...did the bedding in of the brakes but it was still squeeking but not as bad as it was before .Had the dealer cut the sharp edges off the pads and sand the disks/brakes and so far after 2 weeks of driving it had one very light squeek for a second but thats been it .
The brakes used to get worse the hotter it got before the bedding in of the brakes ,I think with kevins cut the edge of the pads and the bedding in the brakes it might have got it ....I'll keep you posted as time goe's by .
Old Jun 19, 2005 | 11:19 AM
  #85
GOFISCH's Avatar
Originally posted by GOFISCH@June 7, 2005, 6:53 PM
Well, now they are squeaking again.
I'm calling tomorrow because it has become worse. Maybe Ford has come up with a fix now.
Old Jun 20, 2005 | 07:39 PM
  #86
mikem's Avatar
No Brake squeak
Old Jul 5, 2005 | 06:42 PM
  #87
Dusty1's Avatar
Now before I get flamed...
No, I don't have a stang yet, but since there was some discussion early in this thread about the problem being the brake pad composition, I just thow I'd through this out there-
I have an '04 F150, 12kmiles so far, no brake squeak. Sounds to me like there is a lot more going on than just brake pad composition. I never "bedded in" my brakes, I just drove to work. Backroads. Not much traffic.
Back in the old days, a squeaking disk brake was fixed by putting a "washer" of sorts between the brake pad and the caliper, or just a bit of grease on the disk sliding surfaces (not on the pad itself! :nono: ).
Now, I don't begin to say I know how different composites (asbestos, ceramic, metal etc) pads sound differently when braking. That's why I said that my '04 F150 has never had the problem. Perhaps the brake pad material is different, but I wouldn't think Ford would change it after only a year.
I hope everyone that has this brake squeal is able to get it fixed. Will the brakes still work? Sure, but why turn heads that way? This Mustang is so great at turning heads by being quiet (well, almost. Love that GT engine sound!)
Old Jul 6, 2005 | 07:54 AM
  #88
gotmy05's Avatar
I just hit 6000 miles and my brakes don't squeek anymore.
Old Jul 6, 2005 | 08:35 AM
  #89
davids2toys's Avatar
I did the beddin in process with 700 miles on the car...time will tell. I did it as a preventative measure, I had no squeek yet!
Old Jul 6, 2005 | 08:36 AM
  #90
When did you bed in your brakes?
Old Jul 6, 2005 | 11:13 AM
  #91
gwin1's Avatar
Question
mines squeaked went to dealer. they replaced pads & calipers.
tech said most of them are leaking from calipers .
Old Jul 7, 2005 | 09:08 AM
  #92
MJC302's Avatar
leaking brake fluid? Mine are noisey only on the rear...no leaks. Is this the first time Ford has used 'vented' brake rotors on the rear? Seems like a harmonic squeal from the rear. The same way you can make a harmonic sound when rubbing your slightly wet finger around the rim of a crystal glass. Different pads are the way to go. Most threads I've read had the problem stop when switching to another manufacturers pads.
Old Jul 7, 2005 | 02:25 PM
  #93
gotmy05's Avatar
When they got tired
They just stoped ya got me
Old Jul 7, 2005 | 02:35 PM
  #94
Redfire1's Avatar
If ya need pads, I recommend Raybestos Quiet Stop. This is their top of the line pads. Have 'em on my '97 Chevy truck and theres not a peep out of 'em.
Old Aug 15, 2005 | 04:03 PM
  #95
Ripstang's Avatar
legacy Tms Member
Well the rear now sqeaking again but not so much the front ,Kevin do you have the new part number for the rear pads ,This is my last chance at this with ford before I take matters into my own hands .
Old Aug 15, 2005 | 04:18 PM
  #96
05stangkc's Avatar
The Original Rear Brake Part# was 5r3z2200aa the latest is 5r3z2200b. But this has been out for months. No tsb's On brakes at this time.
kc
Old Aug 15, 2005 | 04:25 PM
  #97
70MACH1OWNER's Avatar
3600 miles and no squeaks here.
Scott
Old Aug 15, 2005 | 08:50 PM
  #98
Ripstang's Avatar
legacy Tms Member
Thanks Kevin :worship: I'll pass this on to the service manager ,it looks like there going to give this a try .
I'll keep you posted as it goe's along
Old Aug 15, 2005 | 08:52 PM
  #99
Burke0011's Avatar
Big Falken Tires
After I switched out to my Powerslot rotors, bye bye brake squeak......
Old Aug 16, 2005 | 12:26 AM
  #100
Dan's Avatar
Dan
Do You Remember Me?
Did the "bedding in" after tons of squeeking.....no noise for over a month So far so good
