Winter wheel/tire discussion
#301
So it wasn't a 15" - those we're on the back, but still 17" like I said. End of discussion. You CAN fit some 17" wheels on the standard GT brakes. Fact.
#303
Originally Posted by GreenCars
Is there an advantage with going 17" vs 18"? sorry if its a noob kind of question.
Personally, I just want to see if a set of police car steelies will fit on the Mustang because I think it'll look B.A. The 2012 and up Taurus and Utility Interceptors also use 18" 5-spoke steel wheels. If I needed to run winter wheels and tires on my Mustang, that is where I'd be turning first - a) because it'll look awesome and b) keep the wheels OEM but a little different than everyone else. That is, if they fit. Which clearly, I don't know for sure.
#304
#306
I just did a quick search for wheels for a 2013 Explorer on Tire Rack and apparently it uses the same 5x114 bolt pattern and offsets in the 40-45mm range, which is all the same numbers I've seen for late-model Mustangs ...
#307
Well, let's ask him. These are posted in the Kona Blue section. Either way, they fit the 12.8" rotors.
#308
Originally Posted by Gabe
They should fit.
I also did a quick google search of those Weld RT-S wheels I listed, and the 17s fit 2011+ GTs and GT500s with no modification. Obviously, no one is going to run drag wheels for winter, but my point was that SOME 17" wheels can fit the standard GT brakes, and when I know I'm right, I know I'm right. That being said, I'd look for a set of PI Crown Vic wheels and try the, on the GT, or go for a set of the 18x7.5" current PI wheels. I did all this research because I was looking to run a set on my DD Escape (2005) which is also 5x114 and similar offsets. I threw the wheels in my avatar on the Escape and it looked B.A. But the offset was a little too low. Those wheels are OEM 10th Anniversary Cobra wheels which would have plenty of clearance.
#309
Originally Posted by MontrealStang
Sorry my bad ... I thought you meant those were 15" wheels ... Like I said earlier, 17" wheels that clear 2011+ GT brakes are rare
#310
False the caliper bracket is different to accommodate the larger 13.2in rotors ... And the GT has always had larger rotors than the v6 for the same model year ... At least since 2005 !
#311
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
BTW, 2011 V6 have inherited the 05-10 GT's 12.4" rotors (instead of the 11.5" rotors the 05-10 V6 had).
Bottom line, if you stick to OEM wheels, 18" min to clear the 13.2" rotors, 17" min to clear the 12.4" rotors and 16" min to clear 11.5" rotors
#312
Again, the 2005-2010 GT brakes were 12.4" and all non-Brembo 2011+ GT have 13.2" rotors.
#314
I highly recommend sticking with another OEM wheel from a Mustang, Ford Racing, or going through a company like Tire Rack to confirm your setup will fit your car.
#315
Tire Rack confirmed with me that the 17" wheels they list will fit the V6 PP. Also re: smaller rim, you get more choices re: which tire to put on by virtue of the extra sidewall height needed to match the summer tire circumference. In the snow belts, this makes a big difference as you can also play with tire inflations when the going gets really tough.
#316
Discount tire was also great in working with you to find exactly what you need and throwing in things to make the install perfect. I continplated just getting rims and going to a local tire place for the tires. However because they made it so easy I decided to have them do it all. My set comes on Thursday, so all I will need to do is put them on..
#318
I got those TPMS sensors in from Tousley Ford for my winter setup, and I was surprised to find that they also included the reset tool. $120 for 4 TPMS sensors and the reset tool, which everywhere else I looked would have run at least $200... thanks again Overboost!
#319
#320
How many people are going to drive the car in the winter?
Personally, I won't be doing any winter driving until next year, but I've started looking at winter wheels and tires and getting an idea of what it's going to cost me.
Here's what I've found:
18" GT500 wheel (either the 07-09 style or the '10 verts)
Wheel size - 18x9.5"
Recommended OEM tire size: 255/45/18
This is an exact match size for size with the 255/40/19s that the BBP comes with.
Keep in mind, you'll also need TPMS sensors (4), and the calibration tool to sync the sensors to the car. I believe this goes for $100 or so.
If anyone wants to add info regarding the other wheel types and sizes, I can add it to the first post.
I will be using my fan blades, which I just purchased winter tires for, as my winter wheel
