Winter wheel/tire discussion
#221
I just got my Track Pack mustang and I also plan on getting a dedicated set of winter wheels/tires. My current plan is to get some AMR wheels from AmericanMuscle and then ordering a set of Blizzaks from TireRack.com and just having a local shop mount them.
#222
If you aren't going to drive in snow, you'll be fine with all seasons or maybe even summer only. Fact: I drove all of last winter here in DC on summer tires, we only had snow twice, and in both cases, it never stuck to the freeway. That being said, I'm going to get some GT500 18's for winter duty, but I haven't decided on all seasons or dedicated snows.
#223
On Tire Rack, I've been looking at Sport Edition F10 wheels (18x8) with either Blizzaks ($266/tire) Conti Extreme DWS A/S ($189/tire) or BF Goodrich Super Sport A/S ($208/tire). Tires are priced with road hazard, though the Conti's are manufacturer supported road hazard vs TireRack. Does anyone have any experience with these wheels, tires, or trying to use the hazard warranty with Tire Rack or Continental? Any help would be much appreciated, as I have plenty of time to make the decision before I order it all. Thanks!
I used Blizzaks on my Charger for several seasons - they're fine. Good winter performance, and not so bad for "spirited" driving when it's not slippery (almost all of the time last winter). They certainly did not have the sticky grip my summer only tires did, and they tended to break loose rather suddenly, especially during acceleration, but once learned it was predictable most of the time. They're expensive, but since I KNOW they're good I might just go with them again.
I look forward to the Torsen differential on my Mustang this winter also, that should be a big help.
#225
#226
Guys, I merged a number of winter tire, wheel, and driving discussion threads into the one that was started a while ago. Let's try to keep from repeat threads about the same topic.
#228
We're looking to get some all season tires for our 2013 GT500. We won't drive it in the snow but will drive it on dry cold days below 40°. We're ording some 20" CS wheels and some Continental DWS.
20"x9" front with 255 35 20
20"x10" rear with 275 35 20
These are the closest sizes to the stock 265 40 19 & 285 35 20s that I have found.
I wasn't planning to get the TPMS in the new wheels. Is that going to trigger an idiot light in the 2013 GT500?
#229
I've ordered a V6 w/perf pkg car that won't arrive before the snow flies. I'm going to switch the 255/40-19's for 235/55-17's (immediately when the car arrives - this will be my DD). I think they should be low-profile enough to keep good steering response and reasonably 'narrow' for a 3500lbs car (minimize plowing and catching ice or ruts). Steelies are hard to find in this size & spec, so I almost have to go with alloy wheels; the Blizzaks are great but in my experience they become average pretty quickly (which is still far, far better than A/S tires). I'll try something else this time...
I've checked and the 17s will fit OK, but I've never actually driven this car in winter to know that a 19" -> 17" rim size change won't somehow mess something else up in the handling or braking. Has anyone else tried this summer/winter combination?
#230
#231
Yep... Same for all tpms cars. We have winter rims and tires for minivan and tsx...idiot light is on all winter. Np. Will shutoff in spring when the all seasons get remounted.
#232
In case it helps anyone, I put Blizzaks (LM-60) on my 2011 V6. I bought a set of identical rims on eBay. That got me TPS (they had original tires with no miles on them, so I have a set of new summer rubber as well). I knew I could not live with the TPS light being on. I bought the TPS 'tool' from American Muscle for when I do the swap.
I have run two winters with them. It has been great. The first time I drove in bad weather, I felt more safe in this than I have in any front wheel drive (maybe because I learned on rear wheel drive).
Where I am they salt the roads pretty good, so most driving is more wet/slushy roads, but I do get plenty of deep snow.
I have not put weight in the trunk.
#233
You non Brembo guys should look at Ford's black steel wheels for the Taurus/Explorer Interceptors. They are 18x8 and same offset as the stock 18" wheels on the Mustang. Or even the 17" Crown Vic CVPI wheels (17x7.5).
#234
1 Post
Ford Racing's Tire Pressure Sensor kit fits 2010-13 Mustang GT/V6/Boss and 2010-12 GT500.
This kit includes 4 valve mounted tire pressure sensors and the proper programming/activation tool.
Note: Does not fit 2013 GT500 - sensors not approved for use above 155 miles per hour.
Product Benefits
- Complete kit for all 4 wheels
- Includes valve stems and programming tool
- Ford original quality and engineering
#235
I am just looking at a set of stock Premium Mustang V6 wheels with the Michelin all seasons on them, don't think the Pirelli P-Zero's are going to make it up the hill here if it does snow. Although we don't see a lot of snow but we do get cold for days at a time here so the all seasons should do fine.
#237
To stay around our height range, on a 9.5"-wide wheel, 265/45R18
http://www.1010tires.com/tiresizecalculator.asp
#238
Originally Posted by BackinBlack13
What size winter tires for 18x9.5 would you guys recommend?
#240
Thanks guys, appreciate it. Looking at the Michelin Pilot HX MXM4. But have no idea if these are good or not.
