Notices
Revised TSB for Lower Control Arm squeak
Old 8/13/13, 10:16 AM
  #101
wanted33's Avatar
Repaired today.
Just got the TSB done today, and the car is as quiet as a church mouse. Here's to hoping it stays that way. Repairs, plus alignment took approx. 2 1/2 hours. I have to say I'm very glad that my service dept. folks don't come up with some of the off the wall stuff a few of you are experiencing. If only all service dept.'s would work that way.
Old 8/13/13, 08:20 PM
  #102
Currently a Corvette Owner!
PJRManagement's Avatar
I had this latest TSB # 13-7-08 performed last week. I was lucky in that I asked my dealer about this a few weeks ago, and they got on the list of the back-ordered 'LCA kit'. So far, so good.
Ps: I did not have any of the previous TSBs for this issue done, just this latest one with the new 'heat shields'.
Old 8/14/13, 11:51 AM
  #103
FordService's Avatar
Originally Posted by Plim
My car was fixed before the TSB. And was doing ok.....
I need to go back, it started squeaking again (although not as bad as it was at first).
Yes, Plim. Bring it in and PM me with your dealer and best daytime number (since I have everything else) so I can get it escalated for you.
Originally Posted by wanted33
Xar, others here have had their vehicles repaired more than once. I'm sure Deysha will take care of the problem for you.
Me, I'm still waiting on one part to arrive...
Update: 4:00 pm dealer calls....parts are all in.
Thanks for the update, wanted33!
Deysha
Old 8/14/13, 01:55 PM
  #104
Stevedotmil's Avatar
I just found a decent dealer here so I have to try and get this done or at least ask about it to see what they say. Sounding like a 1967 Coupe De Ville when I go over speed bumps isn't cool.
Old 8/14/13, 02:07 PM
  #105
PonyOx's Avatar
What are the odds that the revised parts are being used in the current production runs? My car was assembled in late June so what should I look for underneath to check if I have the new setup?
Old 8/14/13, 03:44 PM
  #106
wanted33's Avatar
It's hard to say Pony, but with the problems many are having one would think Ford would revise the LCA's in the new builds. One thing for sure, if they didn't you will know soon. Good luck.
Old 8/15/13, 12:24 AM
  #107
Xar
Xar's Avatar
Deysha escalated my issue and the service manager has the parts I just need to make the appointment, Deysha - you rock!
Old 8/15/13, 11:30 AM
  #108
SoFlaBoss's Avatar
My service advisor called yesterday to let me know that all the parts for TSB 13-7-8 had arrived, so I dropped off the wife's stang this morning. It should be ready sometime tomorrow. Thanks again Deysha!
Now is probably a good time to drive my 2013 in this heat to see if it makes the same noises.
Old 8/15/13, 05:41 PM
  #109
lakersfreak's Avatar
sorry guys can you explain what noise you all are talking about? Im new to this and acronyms don't work for me.
Old 8/15/13, 05:42 PM
  #110
I do notice a squeaking sound that comes out of what seems like the back seat at times.
Old 8/15/13, 06:26 PM
  #111
SoFlaBoss's Avatar
Just follow the link to a .pdf of the TSB that was posted earlier in this thread. It accurately describes the sound. You'd know if your stang had this problem by just driving it on a hot day. Clearly you haven't heard the noise.
Old 8/16/13, 02:25 PM
  #112
wanted33's Avatar
laker, LCA = Lower Control Arms. The car with squeak, or creak when going over bumps. If your new one has the problem you will know it soon. Mine started at approx. 2000 miles. Hopefully the new builds won't have this problem.
The squeak in your back seat is a different matter that I'm not sure about.
Old 8/17/13, 05:56 AM
  #113
SoFlaBoss's Avatar
Picked up the wife's stang from our Ford dealer last night, and so far all front-end noises are gone.
Unfortunately, the Technical Service Bulletin doesn't include aligning the front-end after replacing the suspension components. Now our car's steering wheel is no longer centered when driving on a straight and level surface, so the front-end is no longer properly aligned. I need to get this corrected asap. I can't believe they didn't do an alignment!
Below are a couple photos taken from under the hood showing the new hydro bushings with their shields protecting them from the intense heat of the adjacent catalytic converters.
passenger side:
driver's side:
Old 8/17/13, 07:27 AM
  #114
F.D. Sako's Avatar
oh man, this might be my problem!
for the past 3 weeks whenever i go over speed bumps, regardless of speed, i hear this horrible sound, like someone's opening a 200year old door lol. I also felt the vibration when it squeaked/creaked.
Old 8/17/13, 09:19 AM
  #115
typesredline's Avatar
Mine just started popping up. 3000 miles on a 13. Sounds terrible, like a lurch. I hate dealers though so it sucks that she will have to visit one.
Old 8/17/13, 02:32 PM
  #116
wanted33's Avatar
SoFlaBoss, thanks for the pics. I haven't even looked since I got the Wifey's home. I surely hope these shields don't just transfer the heat to the LCA's causing the same problem. I guess time will tell. Fingers crossed.
Old 8/17/13, 02:36 PM
  #117
wanted33's Avatar
Yep, that's the what it sounds like.
That's about the same miles when mine started. It's time to rekindle your love affair with your dealer.
Hope the dealers get you both fixed up soon.
Old 8/17/13, 03:45 PM
  #118
SoFlaBoss's Avatar
URW. The Shields should work. I know 05 and 06 (maybe 05-10) S197 had the shields and they were quiet. Not sure why they discontinued using them.
Old 8/18/13, 02:44 PM
  #119
wanted33's Avatar
That's good to hear brother. Thanks.
Old 8/18/13, 04:55 PM
  #120
PonyOx's Avatar
I was able to take a look today and I'm disappointed to find that my late June build car does not have the shields.
Quick Reply: Revised TSB for Lower Control Arm squeak
