Cool Tech Roll Bar - Sneak Peek
#281
Cooltech Harness Clips
Has anyone purchased and installed the Cooltech Harness Clips?
http://www.cooltechllc.com/Boss/Boss_ClipSet2Seat.shtml
Could you take a picture of them installed and post it.
Phil
Phil
#282
Just installed mine tonight. First pic is of the outside with the seat in the driving position. The second and third are pics with the seat folded forward. Not sure if these are the pics you are looking for as the plastic is covering up the bracket. I think in the directions it tells you to discard the plastic trim. I installed it back on instead. Just need a little more pressure to install it. Excellent fit and finish.
#284
Now to try and figure out how to get the sub belts to work?
#285
Originally Posted by nota4re
Clip the sub belts onto the same clips as the lap belts and lay the sub belt onto the seat bottom with in a V formation with the top of the V toward the front edge of the seat. Sit down and pull the V up between your legs. This 6-pt system is a constant reminder to not crash and test the system.... as the "boys" ain't gonna be happy!
Can you show a picture of the sub belt layout? I have a 6 point set and am trying to layout where to anchor them.
Steve
#286
#287
Great Pictures
Thanks for posting the pictures. Just what I was looking for, for a start, now more questions.
Does the Harness clip go on to the seat attachment stud above or below the seat rail?
I like to see pictures of both the sub belt and harness belt in the harness clip?
Thanks Again
Phil
Thanks Again
Phil
#288
Just a suggestion, when you finally clip the belts to the brackets it would be a good idea to put a cotter pin through the little hole on the snap hook. This is done to prevent any accidental opening of the snap latch. I don't know why Crow does not mention this as this is standard practice in the aircraft industry.
Rob
Rob
#289
So is this what you mean? It does help hold the lap belt down but the 'boys" will definantly not like it if you have to use the belts!
#290
Harness setup and clip systems look great.
Are you mounting the shoulder belts to those clips as well, or eyebolts, or rollbar?
#291
The shoulder belts are mounted to the roll bar, the lap and anti-sub belts mount to the cooltechllc.com custom floor brackets on the seat track.
Rob
#292
OK thanks for the clarification.
#293
Thanks Again
Phil
Thanks Again
Phil
#298
Got the roll bar, looking to order the belts,....let me get this straight...the sub belt lays on top of the seat correct?
