2012-2013 BOSS 302
Brake Duct Kit Installation
Old Oct 5, 2011 | 12:27 PM
  #121
4pipes's Avatar
If I remember correctly, the horn segments are plastic....won't rust.
Old Oct 6, 2011 | 07:50 PM
  #122
Jimmy Pribble's Avatar
Jimmy's Instructions - Part 2 (Right Side)
As promised, here is the rest of my write-up, submitted for peer review.
Instructions for the Right (Passenger) Side:
Instructions for the left (driver) side of the car apply to the right (passenger) side of the car, except that instead of relocating the horn (Step 5), you might want to relocate the windshield washer reservoir. This requires some additional hardware (available at your favorite big box hardware store):
  • (2) M6-1.0 x 50 mm bolts
  • (3) 6 mm flat washers
  • (1) 6 mm lock nut
  • (2) 1/2 x .194 x 1″ nylon spacer (I had to drill these out a bit to fit the M6 bolts.)
  • Drill
I recommend completely removing the windshield washer reservoir, installing the brake cooling kit, and then reinstalling the reservoir with new 1″ spacers. The reservoir is mounted to the car with (2) 10 mm bolts and (1) 10 mm nut that is attached to a removable stud. After removing the hardware, pull the washer pump straight up and out of the reservoir and remove the reservoir.
For the left side mount, first remove the stud by sliding it to the right and then pulling it out. From the backside, thread the new long bolt through the same hole, making sure that you use a washer to keep it from pulling through. Thread the nylon spacer onto the bolt, followed by the mounting tab of the reservoir. Secure with a washer and locking nut.
For the right side, thread the new long bolt (and washer) through the front of the mounting tab, then through the nylon spacer, and then tighten into the speed-nut that is in the factory mounting location.
For the upper mount, drill the upper mounting tab and secure using the factory hardware and mounting point. Press the washer pump back into the reservoir and refill.
This the location of the filler neck after the relocation.
Moving the windshield washer reservoir just 1″ allowed enough clearance for the brake cooling hose.
Test and Verify Fitment!
After a couple of days, I checked the fitment of the kit and discovered that on the right side, the wheel had come in contact with the hose and pushed it under a part of the body that then began to saw into the hose. So, I cut the tie wrap that secured the hose to the body, but left the hose tie-wrapped to the front sway bar. This allowed the hose to sit lower and avoid contact with the body. Things move around in there and it wouldn’t take much to destroy an expensive cooling hose, so go for a test drive and then verify that there is still adequate clearance.
Old Oct 6, 2011 | 07:55 PM
  #123
Thanks for the tips (Wayne) and suggestions (Charlie)! I appreciate the feedback, guys.
Jimmy
Old Oct 10, 2011 | 11:25 AM
  #124
ShaneM's Avatar
why move the washer res, the hoses route right into the gap very easily. i left the extra tubing because at was obvious when i fully turned the wheels each way that the extra hose was needed or there woudl be too much pressure on the connections during full turn-in. granted we rarely turn the wheels all the way in.
took the car racing and my somewhat ghetto duct tape to get the ducts to grip idea worked perfectly and stayed put. it's also worth noting that i climbed back under the car after the install and moving the wheels around, noted where the orange was rubbing on the plastic under the car, and then used a couple rounds of tape to prevent the hosing from being cut over time.
Old Dec 28, 2011 | 06:08 PM
  #125
Overboost's Avatar
I'll be using this thread to install mine. Jimmy, thanks for the much more detailed instructions on how to install these. Any other tips or tricks to share? Is getting the caliper off quite easy?
Old Dec 28, 2011 | 09:26 PM
  #126
06GT's Avatar
Due to clearance issues in there, I use the poor-man's impact wrench--15mm box end wrench and a rubber mallet to break the caliper bolts loose, then a ratchet to get em out.
Takes less than 5 mins, I do this before and after every track event as well.
Old Dec 28, 2011 | 09:36 PM
  #127
908ssp's Avatar
Some more spacer pictures.
Old Dec 28, 2011 | 10:08 PM
  #128
5 DOT 0's Avatar
You should make and sell them.
Old Jan 4, 2012 | 03:03 PM
  #129
Yep. That's exactly what I did. Don't forget Loctite when reinstalling them.
(Shane) As for moving the reservoir and cutting hoses - if you don't have to do it, don't do it. We have seen from other reports that we are each experiencing various levels of interference. Maybe it has to do with our individual tolerances and definitions of what constitutes "a good fit." I bet you that our hose lengths aren't the same, either.
Jimmy
Old Jan 7, 2012 | 10:09 PM
  #130
Overboost's Avatar
I started installing my kit today. Regarding the hose, I actually bought some at the Roush sale last year and ended up using it. It looks similar to the Sceet stuff that was posted before, and went on the flanges much easier than the FRPP supplied stuff. I spent a few hours with the g/f helping and got the drivers side buttoned up. I did end up cutting the fender liner a bit, and on the horn bracket, I removed the tab, then removed the horns, flipped the bracket 180*, and reattached the horns in the same orientation. It moved them up just enough to make it through.
For the pass. side, I'm going to have to cut the liner a bit, and possibly put some spacers on the washer bottle to clear. I should be able to finish it up in the morning.
Just out of curiousity, does anyone have the part numbers for the fog light inserts that are totally blocked off? If anyone feels like selling a set, I may be interested. I'm considering running them in the winter to protect snow/ice from going into the hoses.
Old Jan 8, 2012 | 08:03 AM
  #131
SD GT's Avatar
Steve,
Glad the install is going well.
On the pass. side, I stacked washers onto the bolt. Others got bushings from the hardware store.
As for winter driving, look at what I did on this thread. Just buy some black plastic plumbing fittings and slip them in. I run it this way when not on a track. Cheap, easy.
https://themustangsource.com/f813/br...s-made-499783/
Jim74656
May 1, 2023 02:15 AM
DarrenGT
Aug 21, 2015 07:07 PM
AMWill
Jul 20, 2015 08:40 AM
