Notices
Vibration Issues At Highway Speeds
Old 3/12/15, 03:54 PM
  #161
farsidejunky's Avatar
Golden Circle does not have the tool to check pinion angle. They send in another hotline request, & I spoke to the tech. He does not think that there's anything else they can check without actually doing the ring and pinion, so he's going to look into ordering one and they're supposed to get back with me tomorrow to let me know the result.
Old 3/12/15, 03:59 PM
  #162
keltymd's Avatar
They are the same but if they put ford racing 373 in guess what no more warranty because its considered aftermarket and ford will not pay for the install stupid I know
Old 3/12/15, 04:03 PM
  #163
Something I almost forgot to add...
Ford engineers said the vibration was within normal range. The tech looked at me and said that he thought that was crazy, because he wouldn't drive the vehicle the way it's vibrating. But the engineer tried to tell him that it was normal.
For the life of me I can't figure it out. Are they trying to cover this up?
Old 3/12/15, 07:52 PM
  #164
keltymd's Avatar
I think either they don't know what to do to fix it or they know the issue is with the axle housing and they don't have them any more since they shut down the production of these axles early last year or 2013. That or they are like insurance companies deny deny deny
Old 3/12/15, 08:33 PM
  #165
I have been searching for aftermarket housings and nobody makes them that I have found.
What do the Shelbys, Roush and Steeda's use? Same housing different diferential?
Old 3/12/15, 08:35 PM
  #166
keltymd's Avatar
Yep they all keep the housing. I'm thinking of getting a stock pulled one.
Old 3/12/15, 08:37 PM
  #167
What is a "stock pulled one"? If it is what I suspect how do you know it does not have the same problem?
Old 3/12/15, 08:50 PM
  #168
keltymd's Avatar
It's what you think but get one with 3.31 gears
Old 3/12/15, 09:07 PM
  #169
The 3.73s are perfect for keeping the engine in the power band. That is the lousy part of changing the ratio. Did you say Ford has stopped making the 8.8's?
Old 3/12/15, 09:13 PM
  #170
keltymd's Avatar
The 2015 mustangs have independent rear suspension. Ours are the last of the live axles. The ones for the trucks are different
Old 3/12/15, 09:43 PM
  #171
Assuming the housing is the problem, why would you not just swap in 3.73's?
Old 3/12/15, 10:07 PM
  #172
frank s's Avatar
My experience with rear axle problems was with another manufacturer's product. The dealer was very aggressive in trying to resolve them, several major parts replaced, readjusted. Eventually the technicians tired of all the frustrating attempts, and changed the whole rear axle. Jacked up a new car and my year-old car and transplanted everything, wheel-to-wheel. It was the perfect solution, and didn't take all that long.
I don't know if the next purchaser of my rear axle had or noticed the problems, or if the manufacturer knew what the dealer did to solve them. Someone probably would have had some difficulty buying parts for the one I left behind. Numbers from 1970 to 1971 parts were different.
Old 3/13/15, 05:32 AM
  #173
keltymd's Avatar
Ford doesnt even sell the complete assemblies any more and that would lead me to think its because they dont have any more
http://www.fordracingparts.com/parts...KeyField=10353
Old 3/13/15, 01:50 PM
  #174
Hey Kelty, call your service guy. The 3.73's are supposed to come off of back order today according to Golden Circle.
Old 3/13/15, 02:17 PM
  #175
keltymd's Avatar
Sweet. I'll give um until Monday to update me. They are working with me so I don't want to push them.
Old 3/16/15, 09:18 AM
  #176
keltymd's Avatar
you hear anything from Golden Circle yet?
Old 3/16/15, 01:18 PM
  #177
keltymd's Avatar
Just talked with Russell Barnett in tullahoma. The parts are all in and she is on the rack being torn down. He is taking his time and getting all before and after measurements on everything to try and pinpoint where the issue is so they know.
Old 3/16/15, 02:01 PM
  #178
Good. Please let me know what they find.
FWIW, the vibration is now much less pronounced. I think I understand why the engineers were having problems diagnosing. The rear view mirror no longer rattles, and the speed range is now from about 50 to just under 70. 75 is smooths out. Whatever is in the back glass rattling is still there, however.
Calling Golden Circle to see the status of the parts.
Old 3/16/15, 02:04 PM
  #179
keltymd's Avatar
Do you have yours back right now?
Old 3/16/15, 02:17 PM
  #180
Yeah. I picked it up on Friday. There was nothing more they could do besides open up the dif and replace the ring and pinion. They ordered the ring and pinion and figured they would look at everything when they did that.
Quick Reply: Vibration Issues At Highway Speeds
