Notices
Mustang 3.5L Ecoboost engine swap
Old 12/19/16, 08:03 AM
  #1621
Ecostang's Avatar
Ecoboost ****
Attached Thumbnails Mustang 3.5L Ecoboost engine swap-img_0387.jpeg   Mustang 3.5L Ecoboost engine swap-img_4636.jpeg   Mustang 3.5L Ecoboost engine swap-img_5820.jpeg   Mustang 3.5L Ecoboost engine swap-img_0191.jpeg   Mustang 3.5L Ecoboost engine swap-img_1729.jpeg
GLOCKer (12/20/16)
Old 12/19/16, 02:18 PM
  #1622
boss man's Avatar
Location: NJ. Waiting for our Gov. to be held accountable for his actions>>>Jersey Broke
man that block looks very stout now. Should be good for how many HP??
Old 12/19/16, 03:35 PM
  #1623
Ecostang's Avatar
Should be good for 1000 whp
More pics coning soon, the heads are finally done. Engine ships tomorrow!
Old 12/20/16, 01:09 PM
  #1624
lowblustang00's Avatar
Originally Posted by Ecostang
Ecoboost ****
Looks great. Keep the updates coming.
Old 1/2/17, 08:03 AM
  #1625
Andrew Taylor's Avatar
Hello
First post, found your thread looking for a fox body with a 3.7 swap(I'm hitting a lot of issues swapping my 3.7 into my rx7). If I might make a suggestion for fuel. A guy named Joe in Texas swapped a 3.7 into an rx7 fc, he turbocharged it with 90lb injectors but was hitting a brick wall leaning out on the top end stuck at 502@wheels. I suggested a walbro 450, it has dual rotors, check valve and is e85 compatible.
​​​​​i haven't read through your whole thread as I am low on phone data, to see if you have dealt with your fuel needs. You might want to check it out.
One thing I'm wondering is, why direct injection? Ford has had issues with carbon buildup on the back of the intake valves with no procedural fix(as far as I know) besides swapping the heads out. Won't you be limited by injector output and a lack of aftermarket options? I don't have the pocket depth that you do but I sure couldn't afford them.
On my swap I am using a Ford edge 3.7($487) mates to a 2013 v6 mt82($187), 2013 mustang gt flywheel($135w/resurfacing) & spec stage 1($281). I got all of my accessories for $300 and recently picked up a remote mount shift which had a Hurst short shifter for $95 shipped. I think I have a wiring nightmare on my path soon and hope someone can give me a heads up. When I get on wifi I'll read your whole build thread.
My current engine situation
maybe your upgrade will be completed when I'm done with my swap
Old 1/2/17, 08:11 AM
  #1626
Ecostang's Avatar
Well past fueling issues, I'm using DI and port injection.
Old 1/2/17, 08:22 AM
  #1627
Did you upgrade the pump and are you still using the stock fuel management computer?
Old 1/2/17, 08:25 AM
  #1628
Ecostang's Avatar
Yes I used a dual gt500 fuel pump, stock PCM and a pro EFI supplemental fuel controller for the port injection. We are adding a BAP to get to 1000 whp
Old 1/2/17, 08:59 AM
  #1629
That is just disgusting lol what's the weight to hp ratio then? 4:1?
Old 1/5/17, 01:36 PM
  #1630
boss man's Avatar
Don't have much to offer but what ever you do. Do NOT install the Ford factory clutch with the MT-82. At high RPM you will have lock out. You may also think about going with the MGW race spec shifter to complete the package to prevent lockout at high RPM. Also the clutch sticking to the floor is another curse of the stock clutch. Will it happen to you.. Don't know. But to all mustang owners with the 5.0 this is way common. Good luck and would like to see your build as you move forward.
Old 1/5/17, 01:46 PM
  #1631
The Ford flywheel for the 3.7 is a dual mass pos and costs 781 from Ford. I picked up a 2013 gt flywheel for $80, $50 resurface. I'm using a Spec stage 1 clutch for the gt/gt500, new flywheel & pp bolts and dowels. I got the clutch from lmr for $281w/tax and shipping.
Shifter is a Hurst short throw shifter I got online from a wrecker out of a gt500 w/5kmiles. The whole assembly was $95 shipped. They ****ed up an sent me the mt82 tranny mount on accident and then let me keep it for free, lol.
Old 2/9/17, 05:10 PM
  #1632
XRFairmont's Avatar
Hi Stephen,
Any progress of late?
My ecoboost project has had to take a back seat to other commitments of late and I'm looking for some inspiration through yours...
Bryan
Old 2/12/17, 09:52 PM
  #1633
Ecostang's Avatar
Originally Posted by XRFairmont
Hi Stephen,
Bryan
Well I'm leaving this Wednesday towing the car to florida to have the turbos and all the intake/exhaust piping done. Then it will head over to MPT for tuning, then to the track.
I installed the jms transbrake kit, radio delete, and made plastic shims for my aluminum intake to prevent heat soak.
I'm posting more up to date info on my 3.5ecostang
Attached Thumbnails Mustang 3.5L Ecoboost engine swap-img_1837.jpg   Mustang 3.5L Ecoboost engine swap-img_1955.jpg   Mustang 3.5L Ecoboost engine swap-img_1949.jpg   Mustang 3.5L Ecoboost engine swap-img_1947.jpg   Mustang 3.5L Ecoboost engine swap-img_1942.jpg
The following 3 users liked this post by Ecostang:
David Young (2/21/17), GLOCKer (2/13/17), XRFairmont (2/13/17)
Old 3/5/17, 01:51 PM
  #1634
Ecostang's Avatar
If anyone is still out there.....here's an update pic. Will hopefully have it running in a couple weeks
I have a lot more pics on my FB page 3.5EcoStang
boss man (3/6/17)
Old 3/5/17, 01:57 PM
  #1635
Received 2,279 Likes on 1,699 Posts
What kind of power are you making? That looks like a sweet set up.
Old 3/5/17, 02:28 PM
  #1636
Ecostang's Avatar
Thanks! We are going for 1000whp
GLOCKer (3/6/17)
Old 3/6/17, 01:54 AM
  #1637
XRFairmont's Avatar
We're all still out here, patiently waiting for info on the progress of the Ecostang (and maybe enjoying a refreshing beverage or two in the quiet times).
I like the front turbo mount you've used. May need to use that one myself to clear the steering column etc on the XR - are the exhaust manifolds off the shelf or custom made?
Keep the updates coming, have enjoyed every bit of this build.
Edit:just checked your fb page - nothing off the shelf about those manifolds
Last edited by XRFairmont; 3/6/17 at 01:57 AM. Reason: Further relevant information found
Old 3/6/17, 03:42 AM
  #1638
David Young's Avatar
I'm still watching and reading your progress . I just don't talk very much
Old 3/6/17, 05:02 AM
  #1639
boss man's Avatar
Agree with others.....Still here. Sometimes I'm there. But always close enough to be here.
I have watched this baby from when the front end loader delivered the birth of this red head step child, to reading of countless nights of lost sleep, to its trial and error years, to what it has grown into today. SIR, You have raised one BMF.
https://www.bing.com/videos/search?q...44&FORM=VRDGAR
Have you ever given your build a name?
Old 3/11/17, 01:55 AM
  #1640
Quick Reply: Mustang 3.5L Ecoboost engine swap
