Mustang 3.5L Ecoboost engine swap
#562
Thought I was going to bolt in a driveshaft loop from BMR but it turns out that for a V6 you need to take out the driveshaft and put it through the loop, then bolt the loop to the bracket. Booooo BMR! The loop could have been engineered to go over the driveshaft installed in the car but it simply wasn't. I'll probably order a rear loop as well and will wait till then to put the front loop on.
#567
#568
Yes that is a cap drilled out for the (2) 3/4" pipes.
#569
Just an FYI for futer. they do make a WYE fitting (copper)to do just that if you ever come across that need again.
I like many, cant wait to hear that you fired it up and ITS ALIVE!
#570
I searched everywhere for a copper Y in a 1" and couldn't find anything, I would have used one of those for sure. Where have you seen those? Thanks!
#572
1/2 copper in plumbing and 5/8 in ref. Same thing. Its just that ref. uses many differant types of fittings because they only handle a gas/liquad. Plumbing is a liquid/air/soild.
Or you do what you did. Both work and do the same thing.
Its custom work!!
#576
That pic of the extra injector setup is from full-race right? I don't think that will fit under my hood.
#577
#578
I've been working on turbo and intercooler piping, getting all that to fit between the engine and radiator has been very difficult. I've changed my plan multiple times. My plan is to only report back here when I have something that works. I've got things roughed out right now and it all seems to be fitting.
I did get the pump installed, I used rubber feet hoping it will be a little quieter than mounting it straight to the body.
#580
