BBK shorty tuned ceramic headers
Old Feb 15, 2014 | 02:16 PM
  #161
Ajcruz1's Avatar
Originally Posted by hogasswild
Really? Were there any imperfections in the headers?
No not that I could tell.
Old Feb 15, 2014 | 02:39 PM
  #162
CVH's Avatar
CVH
I'd watch those gaskets. They have a reputation for blowing out. I got new Ford ones that are metallic which are much more heavy duty.
Thanks, I will keep an eye out for that! I will have to go grab a set from ford and keep it in the garage for later.
Here is a couple short revs, man I love this setup now.
These BBK shorty headers sound great when you open them up.
I see I have to adjust my driver side muff counterclockwise.
Old Feb 15, 2014 | 02:46 PM
  #163
CVH's Avatar
CVH
Originally Posted by Ajcruz1
I think the stock ones are not providing a good enough seal and that's why I'm having the problems at idle. It's the only thing that's left because I have ruled out the mid-pipe connection and the tune so I'm gonna give the BBK ones a try.
Did you reuse the factory gasket? My factory gasket did look more durable, but had impressions from the factory headers that did not match with the new shorties.
Are you getting a drop in rpms @idle?
Old Feb 15, 2014 | 02:54 PM
  #164
Ajcruz1's Avatar
Originally Posted by CVH
Did you reuse the factory gasket? My factory gasket did look more durable, but had impressions from the factory headers that did not match with the new shorties. Are you getting a drop in rpms @idle?
Yes I did reuse the factory ones because they only have 6K on them so I figured why not. I didn't'the even take them off to look at them tho, probably should have. I guess I could try some new OEM gaskets b/c just like Hogasswild I have also heard bad things about the BBK gaskets. I read somewhere that someone had used copper gasket maker with the BBK gaskets and is going 10k strong with no problems so I'm not sure what I will do yet but I will take everything back apart sometime this week and decide from there. Oh and no drop at idle just a vibration from the engine and I'm 100% sure it's from the engine. It's not real bad though. It's a constant slight vibration with about a 200rpm jump.
Old Feb 15, 2014 | 03:19 PM
  #165
CVH's Avatar
CVH
I have a slight vibration also, I think it is from my exhaust tho. My idle only fluxes from 645rpm-650rpm. It is very solid. I am using an updated Steeda tune.
Old Feb 15, 2014 | 05:49 PM
  #166
Siber Express's Avatar
Actually well over 12,000 now without a problem. I will put the Stock Exhaust gaskets back in if the BBK's fail.
Sounds Good Chris
Old Feb 15, 2014 | 06:45 PM
  #167
CVH's Avatar
CVH
Sounds Good Chris
That's good to hear. I have a feeling eventually that these Gt500s will come off and I will get those Borla Tourings after all.
Old Feb 15, 2014 | 07:53 PM
  #168
hogasswild's Avatar
My exhaust is causing a very light vibration ever since I replaced the x pipe. However, I noticed the stock piece had dampeners on them which the bbk piece doesn't.
Old Feb 15, 2014 | 07:58 PM
  #169
I get a slight exhaust vibration since I replaced the Mufflers around 1800 RPM under a pull. Since I took the Dampers off the X-pipe and the mufflers I am sure that is the cause of that. Not too worried about it
Old Feb 15, 2014 | 08:02 PM
  #170
hogasswild's Avatar
Yeah me either. It just helps with the rawness lol. My wife thought a shotgun went off the other day when the exhaust did its decel popping lol.
wallace
Mar 29, 2016 10:09 AM
Bryanh24
Oct 14, 2015 08:43 AM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
