Steeda Tunes?
#41
I have the drop in k & n filter with their tube. So idk if that makes a difference. I have an automatic car so idk if that makes a difference
#42
The tunes are different for the manual and automatics. In addition, they have different tunes for their CAI and the stock airbbox. You may not have the correct use for your setup. They should be able to tell once they review the data log.
#43
who knows lol. But we shall see if I ever get the data log. I emailed Matt, called him and nothing. TJ was the only one to contact me. I even left Matt a voicemail and email. To me that is terrible customer service. Most likely I won't be buying anything else from them. Or worrying about a revised tune. I'll just go to someone locally. That's just my opinion
#44
You are having a very different customer experience that I have had with Steeda. They have been very helpful and responsive. That is why I have several of their products on my car. I would send TJ a message and explain the situation. He should be able to get things moving.
#45
yea idk what is going on. When I called to speak to Matt, I spoke to some guy and he said I will tell Matt you called and also leave a voicemail for him and I heard nothing. That was over a month ago. I stopped bothering with him. I already have sent TJ a message. He was the one making sure everything was ok. He can only do so much. It's on these other people, but idk we shall see. I hope it's not because I'm a girl but you never know
#47
#50
Last I heard & checked - the tune was with James & he was looking it over to see what he can diagnose - I will double back with him & see if I can get this all resolved.
Thank you for your patience.
Best Regards,
TJ
Best Regards,
TJ
#51
So Matt finally emailed me today and asked me to take a pic of the stock air box bc that could be the problem. I did put what I had on the car on the form they had me fill out smh. Well hopefully this is the problem and they get the tune revised.
#53
#55
They want me to put the stock air box on and do a data log with a stock tune and their tune smdh. I don't have time really to do this!! They said the fuel trim was off. I just don't understand why they just can't fix the tune with the air filter that is on
#56
There are a few CAIs out there that change the mass air transfer function & hence, some of the issues you are experiencing.
Unfortunately, you never know how it will react WITH a tune until you try it.
This is one more step in the process - you have come this far & you have an audience ... we are so close!
TJ
#57
Putting the stock air filter back on is a minor process & little time - I am sure once you do it, you will see the difference & how the Steeda tune is supposed to work.
There are a few CAIs out there that that change the mass air transfer function & hence, some of the issues you are experiencing.
Unfortunately you never know how it will react WITH a tune until you try it.
TJ
TJ
#58
Every engine control unit does some adaptive optimization of vital parameters, like spark advance, air fuel ratio, timing etc. The original software programmed into the engine has a nominal range to all those parameters. Let's say that the factory setting for parameter X is 25 to 50 degrees, with most mustangs running ~35 degrees nominal on average. There are going to be outlines out there, meaning a few Mustangs will run 26 while a few others are running at 49. This can be due to worst case tolerance stack ups, manufacturing deviations, or things being assembles or calibrated just a little off center.
So to me it sounds like your car is one of the ones operating closer to the lower or upper bound. Steeda's tune counts on your car being closer to the nominal value, but it simply is not.
So instead of taking a guess (which is what they would have to do without real data) they are asking you to go back to stock and datalog. This way they can make an educated decision which way to go with their parameter settings. Closer to 25 or closer to 50 in my example. That's what I would do as well. Engineers NEED data.
Hope this helps.
#60
Trust me, I understand the amount of money you have invested thus far & time spent going through the process - I just want to see this through & take that final step!.
TJ
