new TSB on front upper strut mounts
Old Oct 21, 2007 | 02:02 PM
  #121
kh765's Avatar
Originally Posted by blkstang06
Gee! your mind must be in the gutter!! Take two statements remove the sentence in between, to suit your post!...Why don't you! keep it G rated! Do you have anything productive to ad to this thread, other than altering other's posts to suit your twisted mind......
Already have added my comments to this thread. Good to know you can have absolutely no fun though.
Old Oct 21, 2007 | 04:52 PM
  #122
blkstang06's Avatar
Originally Posted by Rash
Can the g-trac bar be installed on ramps or does sit have to be on jackstands? Is it fairly easy to do? If not, how much will install cost me?
Yep! it can be done on ramps! No need to pay someone to do it! Its a simple mod..........
Old Oct 22, 2007 | 02:29 PM
  #123
Rash's Avatar
Cool - thanks. I'll be ordering it soon. I've already had the TSB done, and it's eliminated the clunking, but I have a creak over speed bumps that i believe has to be a control arm bushing. kevinb120 mentioned that it eliminated his "squidgy" sound over speed bumps, so i'm hoping that is the same noise I hear and it gets rid of it. If not, at least I'll have a somewhat firmer suspension, and for only $60.
Old Oct 22, 2007 | 03:02 PM
  #124
metroplex's Avatar
I have the squish sound when going over speed bumps as well. I believe it is coming from the struts. Bushings shouldn't make that hydraulic of a sound.
Old Oct 22, 2007 | 03:10 PM
  #125
blkstang06's Avatar
Charlie, your still running the factory struts right! How many miles on them?
Old Oct 23, 2007 | 05:41 PM
  #126
kevinb120's Avatar
Well its normal for a 'piston' like sound, but not a squidgy-squeak sound.
Old Oct 23, 2007 | 06:17 PM
  #127
metroplex's Avatar
blkstang06: Yep, I'm running all stock suspension parts. I have about 4200 miles on them. I don't drive over speed bumps much, but there's one that I drive over whenever I visit another work site. I can definitely hear the front end going SQUISH while the rear just hops over the bump.
Old Oct 23, 2007 | 06:46 PM
  #128
randy_tho's Avatar
Am I correct in that the convertables and all 08s already have this bar?
Old Nov 4, 2007 | 08:57 AM
  #129
tailwind's Avatar
TSB 07-18-2 is Ford's answer to the clunking noise from the front suspension. As is was published 8-24-2007 I am thinking that it will take awhile for the dealers to get parts as there is bound to be a rush by owners to get the new strut mounts installed under the TSB.
Old Nov 4, 2007 | 10:51 AM
  #130
Stoenr's Avatar
Yeah, that looks like it, contains that part # that was mentioned. Also added on my birthday! Thanks!
Old Nov 4, 2007 | 12:10 PM
  #131
metroplex's Avatar
Where can I get a copy of the TSB?
Old Nov 4, 2007 | 01:13 PM
  #132
Stoenr's Avatar
http://www.allfordmustangs.com/forum...sb07-18-02.pdf
Old Nov 4, 2007 | 02:12 PM
  #133
metroplex's Avatar
Thanks Stoenr.
Old Nov 4, 2007 | 05:04 PM
  #134
http://forums.bradbarnett.net/showpo...8&postcount=32
here too
Old Nov 14, 2007 | 04:55 PM
  #135
MustangLynda's Avatar
posted in wrong thread, sorry....
Old Nov 24, 2007 | 06:16 PM
  #136
LonghornTX's Avatar
A couple questions coming from a prospective buyer of a new 08' model.
-Will the updated upper strut mounts be included on my car when it is delivered? Also, since I plan on lowering the car after I buy it, do these new upper strut mounts provide a suitable replacement for some of the aftermarket mounts by steeda, J&M, and MM mentioned in this thread?
-Also, the same question applies to the factory a-arm brace provided by the factory. Would it be smart to upgrade this with something from BMR or steeda?
Old Nov 24, 2007 | 06:36 PM
  #137
from what I understand the old part is discontinued. With that I would say yes you should have the updated mounts.
I still have the uper strut noise with the newer mounts on my car being lowered 1.3 in the front. Others that are lowered in this thread have stated they no longer have the noise. I don't know if they are lowered more than one inch.
Old Nov 26, 2007 | 10:33 AM
  #138
WaltM's Avatar
Can the new Ford part be substituted with Steeda Caster/Camber plates?
Old Nov 27, 2007 | 08:00 AM
  #139
roger blose's Avatar
Thumbs up Upper Strut Mounts - YES!
I just had the new mounts installed late last week and the difference is amazing. My GT feels totally different over bad roads and is overall more quiet. Almost a luxury feel to the front end now. The dealer made me bring the car in for two days, one to evaluate the clunk, then order the parts, and asecond visit to install the parts. By the way, a 2x2 inch block of styrofoam placed under the carpet (hidden from view), right behind the accelerator pedal will keep your Mustang from being "beat on" at the dealer. You simply cannot floor the gas pedal yet the car is drivable.
Old Nov 27, 2007 | 07:51 PM
  #140
Lime GT's Avatar
Good idea on the styrofoam block.
I think the upper strut mount change has been the most noticable repair done to the s197 yet. It's like a whole new ride. Smoother, quieter, less jarring on tall road bump impacts.
