My steeda (and koni) goodies arrived!!!
#61
Some news I just found out that you might also care about.
Apparently those adjusting collars on the perches need to be mounted with the extended shoulder facing upward, to keep the springs from rubbing against the threads and possibly ruining them.
Really nice of Steeda to ship them upside down, picture them upside down on their web site, and not say anything about it
This is the second pic on their site, the one you have to click on to see, and it shows the correct way to install the freakin thing:
#64
#65
Steeda adjustable rear spring perches along with their Steeda/Hypercoil rear coilover springs in a 200 lb rating.
The coilover springs are quite a bit shorter than the regular Sport springs, so they're definitely needed when installing the adjustable perches:
And the way I have them installed:
#67
My setup though does not include that rubber boot. Was I supposed to reinstall those on the perches? Ooops if I was. I've been running them like that (see my pics on page 2) for over 2 years, no issues. I don't think I'll change anything... but just curious. I don't have the rubber piece or the cap.
As for the ride/drive, you can see from my prior posts that it has been AWESOME. I love the setup. Gabe has the exact same setup as me (except his fronts are the older Konis).
#68
Gabe looks good!
I am currently using Roush lowering springs. Do I select the 200 or 175 lb spring?
#69
I meant the black cap that is on top of the black rubber that Gabe has...
#70
I have adjustable 05-09 Koni shocks/struts with GT500 front upper mounts, front springs are still the Steeda Sport springs I installed when I installed the Konis, about 2 years ago I think.
Gabe looks good!
I figured I should keep using it when I did the perches and I just moved it from the factory perch to on top of the new perch.
You may want to at least check the threads of your perches where the springs are rubbing on them.
Having the perch adjustable part (the "collar") with that shoulder upward will make it so the springs won't rub against the threads and damage each other.
I definitely plan on flipping mine upside down.
It was another factory piece. I popped out of the top of the factory perch and stuck it onto the Steeda perch to keep dirt from going into it
Burton, did your perches come with an adjusting tool?
Mine didn't, I'm looking them up and it looks like it's another $15.70 for the thing, plus shipping ...
#73
I actually cut a bit of one of the rubber seats' tops, to see if it would go down lower, and it seems like it did, but the spring still wouldn't sit down fully until I removed the rubber seat altogether.
Oh, and about the set-screws ... they have little attachments at their tips, which make "threads" when the set screw is screwed in:
As you can kinda see in the pic above, the attachment isn't lining up perfectly with the threads (at least not in that pic), but the attachment moves freely against the set screw, so as long as it's lining up with the threads when you thread the collar onto the center piece, the set screw will push it against the threads on the center piece and not damage the threads
#74
Today I took my new rear spring perches apart and installed them the right way:
I have more pics in my thread
#75
So, at 3 inch setting on the perch, your fender height is 29 inches? My car with the Roush springs now is also at 29 inches. I am rub free about 90% of the time. I might still get this adjustable perch and spring though. btw, for everybody's info, my rear wheels are 20x10.5 +45 offset, and my tires are MT 305/35/20.
And yes fender height is "about" 29 inches.
Varies from side to side, will get re-adjusted again soon
#76
Can you take pics when you have made your adjustments?
#77
9/24/15 09:15 PM
