Factory Engine Cover $$$$$$$$$
#361
Kevin: you are definitely "The Man". Many, many thanks for your hard work, long hours and extra effort to keep us informed and to accommodate our needs and demands, for info and products.
This guy is the best, folks. He won't steer you wrong.
#362
The Analog Admin!
Received 2,992 Likes
Originally Posted by superman112
where is that listed??? any spec's on that brace?
#363
http://images4.pictiger.com/thumbs/c...23813c8.th.jpg http://images4.pictiger.com/thumbs/c...1563fc9.th.jpg http://images4.pictiger.com/thumbs/1...860ba19.th.jpg
Host Images with PicTiger CLICK TO ENLARGE!
Time to End any Confusion. I Installed one this Morning! Here are the CORRECT Part numbers and Torque Specs. This is INCH Pounds Remember NOT FOOT Pounds! You need Qty 2 Part# w520411-s437 5mm Flanged Nuts and Two W712289-s437 Step Studs 6mm at the Base 5mm at the top! PIC 3 is 05/06 Bolt vs 07 Stud. Side NoteYour Local Dealer will probably want to sell you Package Quantities. The Studs come Pack o Two and the Nuts Pack o four!
kc
kc
#364
Originally Posted by vicmeldrew
ok i am tech not a wiz kid - where in this is the torque specs? thanks
#365
Originally Posted by AFChief
Index 3 and 4 in the exploded pic. 89 in lbs for the stud and nuts on the throttle body.
#366
thanks for the reply; is the 89 in for both the throttle body and the bolts in the back as well - tried looking at the pictures but they are so small i cannot print out - the diagram is out of focus.
But it only shows the front, not the rear.
#367
Originally Posted by Stoenr
The pic link doesnt work right in a qoute, try this link http://server4.pictiger.com/img/4008...engcover-1.jpg
#368
The Analog Admin!
thanks that worked; just so i understand this - i ordered the two part numbers for the bolts and both of these will go into the top and bottom on both sides of the throttle body; what about the two bolts in the back of the engine cover - do i just use the existing ones? and do you have any idea what the torque on these would be? thanks again
[img=http://images3.pictiger.com/thumbs/84/65c8eb8ee2bd6ff2ea282df4e820df84.th.jpg] [img=http://images3.pictiger.com/thumbs/a1/54520c846accc39f7d7dc423876316a1.th.jpg] [img=http://images3.pictiger.com/thumbs/54/9111024c7725c054f2c28eb179fbaa54.th.jpg] [img=http://images3.pictiger.com/thumbs/ed/ff948c65869616255848f537644aeaed.th.jpg]
Free Image Hosting - PicTiger
#369
Here is what you do. Remove the two upper throttle body bolts. Install the Two new Studs in Upper throttle body DO NOT OVERTIGHTEN! Pull off the wiring Snap fit Connetors at the rear of the Intake on the fuel rail studs. Slide the cover over the New Studs in front. Slip the rear of the cover over the Rail Studs. Snap the Wiring Snap fit connectors back on. Install new Nuts on New Studs and you are done!
Thanks a lot; this makes it easy; i really appreciate your help.
#370
The Analog Admin!
You Are Welcome!
kc
kc
#371
The Analog Admin!
#373
Queen Of Nascar
Originally Posted by TheMustangSource
Hey Kev,
Mine came in Friday and looks great. It'll have to be modified to fit around the MRT fuel rail, but so did the Midwest piece.
Hows the match to tungsten? Is it going to match my JLT tube a little, kinda, sorta??
#374
The Mustang Source FOUNDER
#378
Queen Of Nascar
Installed:
![](http://www.2005stang.com/gallery/albums/userpics/10007/normal_poweredbyford%20005.jpg)
While not a perfect match, I like it better than the one I had before. Easy install. I think I will get me a silver decal of some sort for the intake tube......
#380
Installed:
