Well a parts car really. 96 base coupe w auto. Got it for $300 runs and drives. Only issues are it won't charge the battery, bad inner right tie rod and power window motor are free wherling
Debating if i part out the 96 or not. The car is in fairly good condition, and I hate wasting good stuff. Besides my dad likes it. He says it's better than the 94 cuz it's a v6 and won't waste gas Good thing I don't think so
Next on the to do list:
Fix or swap transmission
rebuild alternator
locate upper gt40 plenum
94-95 elbow intake adapter
throttle body 65mm or more
locate gt40 or better heads
roller rockers
gears?
I replaced the busted ball bearing in the alternator and put a new voltage regulator. It's as quiet as it can be still need to wait for a gt40 upper plenum to arrive in the mail I'm still procastinating to take out the transmission
I found the dash adapter. Was inside a box stashed with some automotive supplies. I started by removing the old head unit. Still not much progress though.
I began the removal process of the old head unit and single din dash beezel. Dash needs to be cut for the new edge double din beezel to fit. After that, figuring out what I'll do to secure the new head unit so it won't fall off. I already have a dash kit for a later model ford that will help me with that.
