2000 mustang turn signals and hazards arent working
Old Oct 29, 2017 | 04:45 PM
Jordeck2390's Avatar
Recently got me a 2000 mustang standard v6 and i can not figure how to fix my no turn signal and hazard light problem ive checked and replaced the bulbs, replaced the multifunction switch, checked every fuse and replaced the flasher relay and still nothing it leaves me frustrated the only action i get from the two is if i turn the hazards on and only the hazards the lights will come on but wont blink like there suppost to somebody please help me lol
Old Oct 31, 2017 | 10:20 AM
wanted33's Avatar
When you say switch does that mean the turn signal level itself? If so, you've done everything I could think of myself. Hopefully someone else will have a more definitive answer. If not, you may want to post your question the "SN95" section of the forum. Good luck.
Old Oct 31, 2017 | 03:15 PM
Old Oct 31, 2017 | 03:26 PM
yeah thats the (switch) im talking about....idk im thinking it could be a ground somewhere but im still kind of new to messing with cars and im not 100 percent sure where all the grounds for this specific problem are at.... but thank you for your reply ill try and figure all this out and post it where you told me to
Old Oct 31, 2017 | 03:36 PM
Unhappy turn signal and hazards not working
have a 2000 mustang thats giving me problems the turn signals and hazards arent working the most i get is when i push the hazards they come on but dont blink,
ive replaced every bulb, the multifunction switch on the steering column and the flasher relay, ive checked fuses as well any ideas on what my problem is
Old Nov 1, 2017 | 05:13 AM
Evil_Capri's Avatar
Merged threads . . . . there was no need to create three separate threads.
Old Nov 1, 2017 | 04:48 PM
yeah that was my bad i thought i was putting it in a different category like the first guy recommended still learning this site
Old Nov 2, 2017 | 10:43 AM
wanted33's Avatar
At the top left of the page you'll see "forums", hover and a drop down will have "Mustang by Model Year", hover and the drop down will have "SN95". Click that, and then post your question there. There's a lot of good folks there that may be able to help ya. Good luck, and as you say it could be a ground wire.
Old Mar 27, 2021 | 02:53 PM
Marty M Mckee II's Avatar
Did you ever resolve this issue? Im having the same problem, I’ve replaced the multi switch twice and tried 4 different signal/flasher relays all bulbs are good both fuses are good under the dash. I’ve also replaced the fuses just to be sure.
Old Mar 27, 2021 | 03:57 PM
houtex's Avatar
First, welcome to the forums!
So the thing is, it's been 4 years, and the last time OP posted was... well, here, that last reply two above your post.
Let us reset a little bit... you have the same problem? You get no turn signals at all? And your hazard switch makes the lights come on, but not flash?
If yes on both, well, that's indicating a problem with the flasher or the multiswitch... which you've replaced each multiple times, so it's obviously not either of those, unless you've had some *incredibly* bad luck.
So... now what. Well, now what is I don't actually say to go to google, and I don't actually say to search for '99-04 Mustang Shop Manual', and I absolutely don't say to go to *mumbles the name of some other forum that pretty much shows up first or second link* and whatever you do, don't click on the link that might possibly send you to a really badly designed website but what still has a certain file I can't mention, being sure to click on the upper left 'get it 66.11MB' button thingy, and let's be sure to not download said obscurely referenced file and then bring it up in Adobe Reader once it's on your computer.
Yessir, none of those things need to happen. With that semi-necessary silliness outta the way for legal reasons because apes together strong and I like the stock and this is not legal advice and all that....
You (don't) get that and you look on page 4179. There's the wiring diagram.
Now you acquire a multimeter (no really, I mean it this time, get one) and... yeah. Start tracing. There is likely a short or an open connection or a bad ground... it will be a chore, and you won't like it and it'll just be awful... or maybe it'll be the first thing you look at. Either way, this is how you solve it. Tracing/testing/all that.
The most likely problem is a ground that's bad, causing the electricity to want to flow to the next best ground. So I'd check those first, and the diagram shows you where they'd be, which are the left front and right front of engine bay, the right rear of trunk, and one somewhere under the dash center. If you can't get to the ground bolt/connections, you may have to resort to making a new one. Be sure to bare metal all parts of that ground, then spray with paint or rubber after making that happen. Also, be sure where that new screw is going to go doesn't interfere with anything else. Would kind of be a bummer to stick a new self-tapper in the firewall and punch a hole in brake line or something.
I'd also test for 12V at both inputs of the flashers, pins 2 and 3, where 2 is key on only, and 3 is always on.
I'd also be looking at *any* modifications from stock that might have something to do with it. Not talking aftermarket flashers or multiswitch, but some alarm or something like that where they hack into the wiring. If that applies, that is.
And then... after that... continuity checks from point a to point b, which will require some long wires between ends, and then solving any weirdness in between.
No lie, this is going to (siphon with a large amount of negative pressure), but it's going to be the only way you're solving this, tracing and testing. Always fun chasing down electrical issues.
Hope that helps, and good luck!
Old Mar 27, 2021 | 07:43 PM
Thank you!
the light blue wire was backed out at the harness before the multi function switch 😬, wish I would have started chasing wires sooner. Could have saved $150. On the bright side I have turn signals again, so I can go through 4 ways a lot safer now 👍!
Old Mar 28, 2021 | 10:46 AM
houtex's Avatar
Glad it's fixed up!
Old Jul 9, 2022 | 11:01 AM
SDGT's Avatar
was wondering about this, i have a 2000 GT, i was replacing the radio that did not work in the car, so before i pulled the battery cable off i pulled the radio to see what they had going on, was a huge mess that caused a blown fuse, replaced fuse, now i have no brake, turn or hazard signals, i replaced the relay and still nothing, i removed the after market tail lights put bulbs back in and same issue, although with after markets in and bulbs i have lights, when i turn the headlights on i get tail lights, but no brake or turn, looking for ideas before it becomes an insurance claim
claysstang
Apr 18, 2014 04:03 PM
Brian Berthold
Oct 4, 2013 05:24 PM
devanslive
1994-2004 V-6
Sep 6, 2012 07:24 AM
5.0fish
Jun 29, 2011 09:18 PM
BamaRon
1994-2004 V-8
Jul 10, 2008 03:42 PM
