Mustang died ...Also battery keeps draining. .
Old Sep 10, 2015 | 10:47 PM
Uofmrampage's Avatar
"Hi! I have a 2001 Ford Mustang 3.8L and for 2 weeks the battery light has been on...The battery is brand new about a month ago I got it and the alternator has been running fine. Today the battery died and the car even died while I was driving home...soon as I jump it it makes a weird noise like a siren pitch from a fire truck but not too loud if you understand. .. anyways I pushed the window button to roll the window up and then the engine stalled and battery died. . I'm hoping this can be a easy fix...not sure what to do
Old Sep 11, 2015 | 11:29 AM
Jim74656's Avatar
Sounds like the alternator has failed, go to a local parts house like Autozone and have them test the battery and alternator and check them both out.
Old Aug 2, 2022 | 02:55 PM
Smanly's Avatar
I am 95% sure your alternator died. If the battery light is on, you should put in a new alternator and make sure you check your wires for corrosion and exposed lines. Check the terminal too. I had a problem with corrosion on my battery. If you have an AutoZone near you, get a terminal brush to clean it.
minininja2121
Jun 11, 2017 09:57 AM
mellied10
May 8, 2011 08:58 PM
Whosit
Mar 1, 2010 08:04 AM
08VistablueGT
Jul 7, 2008 09:42 PM
Scarpi
Dec 30, 2007 11:29 AM
