still having problems with turn signal -- HELP
Old Sep 29, 2013 | 08:19 PM
Brian Berthold's Avatar
ok so i switched blubs - bulbs are fine
parking lights work
Hazards work
i took alcohol via Q tip and cleaned contacts as much as i could
i have absolutely no experience with electrical
all turn signals work except the front passenger one
any help would be great
if anyone has a diagram of the wiring harness (i know the turn signal leads are taped up with the headlight and goes down to somewhere) that would be great also (in case i say screw it and replace the whole harness)
i cant afford much since i have a ticket to pay for cuz of the turn signal :-(
Old Oct 1, 2013 | 04:57 PM
AzPete's Avatar
If the hazards work, the wiring should be good from the dash to the light as they use the same element in the bulb. The problem possibly lies between the hazard switch and the multifunction switch (turn signal switch). Not sure if you replaced the multifunction switch from the last posting on this issue.
Old Oct 1, 2013 | 06:35 PM
have no clue even how to do that AxPete
Old Oct 2, 2013 | 06:32 AM
AzPete's Avatar
Look up how to change the multifunction switch for your year car. It might be easier than you think.
Old Oct 2, 2013 | 11:55 AM
oh wow that does look easy
but
AzPete if it was the switch wouldnt the rear passenger side be out also??
Old Oct 2, 2013 | 03:30 PM
AzPete's Avatar
No....they have to operate separately because the brake lights use the same wire and filament as the turn signals. I don't have a wiring schematic for the system but the older cars I restored were that way. Might be worth the price of a switch vs taking it to a shop for diagnostics and repair. I hate throwing parts at a car with out knowing but sometimes it comes down to a dollar figure....and hope it works.
The only way to be sure would be to locate the plug for the multifunction switch, find out which wire feeds the offending signal, and, with it still plugged in, see if there is power when it is on by using a digital volt meter.
Old Oct 3, 2013 | 09:26 PM
well i replaced the switch and it works fine down ... thanks AZPete!!!
totally separate
i also took some sandpaper to the inside of the Distributor Cap ... the thing that spins and the points ... starts alot better now !! and i bought the Haynes manual for the car .... next is gana be spark plugs (im playing run chase the car since its 20 years old all original)
Old Oct 4, 2013 | 09:15 AM
AzPete's Avatar
Glad you got it sorted out. Now....read that manual when you have nothing else to do...l o l
Old Oct 4, 2013 | 05:24 PM
already started ... its in the bathroom BAHAHAHAHA
PonyMuscletang13
Sep 26, 2015 02:33 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
DrisStang
Sep 14, 2015 06:20 PM
Linkspure
Sep 12, 2015 06:33 PM
Sep 8, 2015 10:45 AM
