Engine Start Button
#326
I have it on my 06 and yo can have both ways Just don't "cut" the ignition wire , splice into it and both the button and key works!!
#327
If you look further into this thread, you'll see that you can cut the ignition wire and only have the button start the car. I did this, but just in case, I also have a switch underneath the steering column to allow me to flip between the button or the key to start.
Cheers
Cheers
#328
I decided to order the Honda S2000 engine start button. I went back and forth over that and the Ford GT style and decided that the Honda one is a lot cheaper which saves me some money to afford another goody mod, plus I decided I like the chrome ring which complements the radio ***** and the way it mounts inset of the power point hole.
I know to some it seems redundant and uncessary to have the start button, bit it is sure more visually interesting than the useless power point with the little flimsy cap that I am always afraid of loosing.
#329
I finally got my start button and it is installed! Looks great and I am happy I chose the Honda button with the chrome ring that compliments the radio *****. I chose to cut the green wire on the ignition switch harness and have the start button start the engine exclusively.
I discovered on 2008 Mustangs they changed the power point hole in the dash bezel so that you no longer have to trim away a plastic barrell on the backside. All you have to do for the Honda button is just trim the diameter of the hole just enough for the button to pop in.
#331
I just bought the Ignited one, in gray (since my interior is black and gray). I figured most of you have purchased the red one, so I'll be posting pics when I get it installed
#332
#333
Cheers
Cheers
how do you turn it off if you did not use the key?
#335
I wired the start button the same way used in the Ford Racing PDF installation file for the genuine accessory Ford GT start button. There is techically no difference whether the ignition switch is turned to start it or whether you use a button to push. All you are doing is redirecting the current to the start button instead of the start position on the regular ignition switch. I used the wires that are in the connector harness that plugs into the back of the ignition switch. This is the only proper way to connect ANY start switch. Do not tap into any other power source. It is not even necessary to do so regardless of what any manufacturer's instruction says. The white wire on the ignition switch harness feeds the ignition switch power and the green wire on the opposite end of the ignition switch connector starts the engine. I tapped into the white wire with a Scotchlock connector. Do not cut the white wire in half. The green wire I did cut in half and disabled the ability to start with the key.
The radio goes off with the start button just like it does with the regular key switch when it is turned to start. This start button kit I ordered came with a relay. It's use was recommended for the durability of the push button itself and I decided to use it. From the relay, I connected the ground wire to the ground wire that was no longer used for the power outlet. The Honda start button has illumination. It's wired into the main wire powering the relay so that when you turn the key to run position it stays illuminated.
Optionally you can cut the green wire from the harness and just have the start button start the engine exclusively, or you can just tap into it without cutting it in half and retain starting the engine by both the key and start button.
And yes, when ignition key is turned off it kills the ignition. If you try to push the start button when the car is already started it will not spin the starter and grind it. There are no funky messages or strange lights in the instrument cluster when I use it.
#336
Cheers
Cheers
#337
This green wire illustrated is the one you may cut in half to make the engine start exclusively with the start button.
#340
Your flip button is not even necessary. Just tap into the green wire without cutting it free from the connector and it will start with either the key or button.
As for the oil pressure warning - I don't get it unless I wait a touch too long between turning the key to 'on' and pressing the button. As I said before, you should get the same thing if you turned the key to 'on' and waited before you turned it the rest of the way to start the car.
Try it.
Cheers
