Window issue
Old May 8, 2008 | 09:41 AM
DynamicmustangGT's Avatar
Window issue
So now that I charge the battery up after the winter, the roads are all swept, etc...I re-calibrated my windows 5 times now, however the glass is not leveling to the trim in the down position and is noticeably worse on the passenger side. Any one else with this issue? Suggestions?
Old May 8, 2008 | 09:44 AM
adrenalin's Avatar
So I assume you have a 2005 with the global window feature. Did you completely lower the window, then hold the switch in the up position, let it completely lift into the closed position and continued to hold it for 2 more seconds before releasing the switch?
My drivers door window sometimes drops below the trim on the door, but not very often.
Old May 8, 2008 | 09:52 AM
They went all the way past the trim to the down position, then they went up. Then back down, they are sticking up past the trim by 1/4" or so.
Old May 8, 2008 | 04:36 PM
RRRoamer's Avatar
That is pretty well normal as far as I can remember. That is how both windows on my 05 sit.
Old May 8, 2008 | 07:33 PM
They used to sit even with the trim is why I'm asking. I put my arm up there sometimes and now I can't.
Old May 8, 2008 | 08:13 PM
theedge67's Avatar
Try unhooking the battery again and starting over. If that doesn't work, you can clear the window module memory by unhooking the battery WHILE rolling up or down the window, then starting over.
Old May 8, 2008 | 09:07 PM
DoctorQ's Avatar
Sounds like you need to take it a step further and perform a de-initialization procedure of the smart motor / side window glass.... followed by re-initialization. The following post below has worked successfully for others to get their windows re-set:
http://forums.bradbarnett.net/showpo...1&postcount=10
Old May 9, 2008 | 01:20 AM
Thanks everyone for the suggestions, nothing seemed to work though and the cars warranty was up a few months ago. I guess I'll take it to the dealer...can't cost too much right?
Old May 9, 2008 | 04:49 PM
Arrow's Avatar
Normal for mine.
Funny story, a week after I got mine (Aug '06) I had it back in to have the stripes put on. At the same time I asked them to take a look at the passenger side window 'cause I happened to look over one day while it was down and noticed it sticking up a little from the edge. The tech said it was normal, and I was about to argue when I noticed that the driver's side window was doing the same thing...just hadn't noticed 'cause I had my arm over the sill. lol DOH...
I do know that the windows CAN in fact go down about 3/4 of an inch more, but I think the window position sensor is setup to keep it like it is. Don't know if that can be changed.
Old May 10, 2008 | 05:36 AM
Problem resolved, I took it in to my body shop yesturday and they removed the door panels and reinstalled them for me (as this had solved a similar issue on an Acura). Maybe something was out of alignment??? Speaker maybe??? Anyway it worked and I saved myself the time and money that the dealer would have sucked out of me.
Road_Runner
Sep 2, 2024 04:46 PM
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
