Mounted Camera over tag attached to trunk, powered through wires in the dash and the reverse signal wire connected near the eec (black/purple wire) X marks the plug that contains the reverse sensing wire.
Wow. That's a really nice and clean looking install! Can I ask how you mounted the rear camera? I have a '01 Cobra that I want to put a rear camera in. I'm replacing the stock head unit Mach 460 with a Sony XAV-5500 and figured while I had everything open I'd install a rear camera as well. Thanks so much!
I mounted it under the trunk lip between the tag lights. Don't mount too close to the edge, the structure on the truck lid won't allow the camera to sit flush. The closer to the tag wall the better. I drilled my hole about 3/4 in off the flat wall.
