double din with rear view camera
Old Apr 27, 2020 | 09:04 PM
konasnake's Avatar
Double Din radio into 2003 Mustang Cobra
Recently finished installation of a double din Kenwood DDX8706s with camera in my Terminator. Straight forth installation, just used the following adapters:
Metra - Turbokits Aftermarket Radio Wire Harness Adapter for Select Ford Vehicles - Black Model: 70-5519
Metra - InDash Mount for Select Ford, Lincoln and Mercury Vehicles - Black Model: 99-5029
camera:Universal Rear View Flush Mount Backup Camera : BOYO Vision VTB123HD
Mounted Camera over tag attached to trunk, powered through wires in the dash and the reverse signal wire connected near the eec (black/purple wire) X marks the plug that contains the reverse sensing wire.
works great. See pictures.
Old Mar 13, 2021 | 01:53 PM
Mattlear's Avatar
Wow. That's a really nice and clean looking install! Can I ask how you mounted the rear camera? I have a '01 Cobra that I want to put a rear camera in. I'm replacing the stock head unit Mach 460 with a Sony XAV-5500 and figured while I had everything open I'd install a rear camera as well. Thanks so much!
Old Mar 18, 2021 | 05:40 PM
konasnake's Avatar
I mounted it under the trunk lip between the tag lights. Don't mount too close to the edge, the structure on the truck lid won't allow the camera to sit flush. The closer to the tag wall the better. I drilled my hole about 3/4 in off the flat wall.
Siber Express
Dec 5, 2012 09:54 AM
TacoBill
05-09 Interior and Audio Mods
33
Sep 8, 2012 09:07 AM
jedikd
Nov 1, 2008 04:54 PM
tom281
25
Nov 19, 2007 01:20 PM
hags1
31
Jul 11, 2007 09:40 AM
