Air Bag Light Staying On
A 94 GT I may be going to look at the owner says he had to replace the speedometer and ever since the airbag light has stayed on? Any ideas how this is cleared? Thanks
there's a 10 amp fuse under the dash for the bags check that first. There's also a 20 amp fuse under the hood for the bags. Check those first. If it's neither of the fuses it will be the control module under the radio its a dealer specific part and its $350.
I had the same trouble as you and it turned out to be the 10 amp fuse
