Air Bag Light Staying On
Old Nov 24, 2009 | 03:09 AM
Justin's Avatar
A 94 GT I may be going to look at the owner says he had to replace the speedometer and ever since the airbag light has stayed on? Any ideas how this is cleared? Thanks
Old Nov 24, 2009 | 05:34 PM
cntchds's Avatar
Usually the light staying on means that the airbag has some sort of malfunction, so I would bring it to the dealer. Airbags are not something that I would trust myself with.
Old Dec 25, 2009 | 08:58 PM
bluethunderhorse's Avatar
there's a 10 amp fuse under the dash for the bags check that first. There's also a 20 amp fuse under the hood for the bags. Check those first. If it's neither of the fuses it will be the control module under the radio its a dealer specific part and its $350.
I had the same trouble as you and it turned out to be the 10 amp fuse
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
DrisStang
Sep 14, 2015 06:20 PM
TripleBlack14
Off-Topic Chatter
Sep 12, 2015 01:03 PM
14Glassback
Sep 11, 2015 04:50 PM
