Mustang 2004 V6 backfire problem
Hi guys, I have a 2004 (the anniversary model) V6 convertible. It suddenly started stalling and backfiring when I press the gas pedal too hard while it's on Neutral. When I'm driving, It stalls after I take my foot off the gas and then try to accelerate again. While I'm driving and I hit the gas, It reacts accordingly, but it breaks from time to time and smells like bad-burned fuel (if you've driven behind an old pickup truck, you know what I mean). I tried to get some trouble codes with OBDII, but it doesn't throw anything. I'm thinking about bad timing or leaking injectors , but I don't want to replace everything with no results.
Thank you in advance for your suggestions!!!
O.K. guys, I saw that I have 56 or something views. I was waiting for an answer for a week! Are you afraid to give a suggestion or what? Because I am not like some guys that when they solve their problems, they just stop communicating, I'll tell you how I solved MY PROBLEM: First, I changed the plugs and the cables(no change), then, I cleaned the MAF with a MAF cleaner(no change), then, I cleaned the throttle body(it wasn't dirty anyway), AND FINALLY, I found that my coil is bad: as I said, OBDII didn't give me any trouble codes. What happened was that the coil was cracked and the spark was going everywhere else, but not to the plug.
I hope, everyone who has a problem and had found the solution, to share with all of us!
This is why we've signed in this forum!!! Correct me if I'm wrong!!!
