Mustang 2004 V6 backfire problem
Old Sep 6, 2015 | 06:02 PM
Hristofor's Avatar
Question Mustang 2004 V6 backfire problem
Hi guys, I have a 2004 (the anniversary model) V6 convertible. It suddenly started stalling and backfiring when I press the gas pedal too hard while it's on Neutral. When I'm driving, It stalls after I take my foot off the gas and then try to accelerate again. While I'm driving and I hit the gas, It reacts accordingly, but it breaks from time to time and smells like bad-burned fuel (if you've driven behind an old pickup truck, you know what I mean). I tried to get some trouble codes with OBDII, but it doesn't throw anything. I'm thinking about bad timing or leaking injectors , but I don't want to replace everything with no results.
Thank you in advance for your suggestions!!!
Old Sep 10, 2015 | 05:27 PM
Hristofor's Avatar
O.K. guys, I saw that I have 56 or something views. I was waiting for an answer for a week! Are you afraid to give a suggestion or what? Because I am not like some guys that when they solve their problems, they just stop communicating, I'll tell you how I solved MY PROBLEM: First, I changed the plugs and the cables(no change), then, I cleaned the MAF with a MAF cleaner(no change), then, I cleaned the throttle body(it wasn't dirty anyway), AND FINALLY, I found that my coil is bad: as I said, OBDII didn't give me any trouble codes. What happened was that the coil was cracked and the spark was going everywhere else, but not to the plug.
I hope, everyone who has a problem and had found the solution, to share with all of us!
This is why we've signed in this forum!!! Correct me if I'm wrong!!!
Old Sep 10, 2015 | 06:45 PM
SpectreH's Avatar
Glad you solved the problem and gave us the answer. I didn't have any ideas at the time I read your post.
Old Sep 11, 2015 | 12:05 PM
Jim74656's Avatar
Just saw this post and was going to suggest a coil change to correct the problem, but you already posted, plus this section is generally slow and I usually stay in the main forum section for our SN-95 cars...if I had seen it sooner I would have jumped in to help
apial
Sep 6, 2015 10:40 AM
trackpack13gt
Jul 23, 2015 11:13 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
Will3212
Jul 16, 2015 10:30 AM
Ecostang
Jul 11, 2015 09:06 AM
