2005 GT Driveshaft Prop
TMS Denmark S-197 Fan
Hi.
In the last time I can hear a click sound everytime I drive close to a building etc.
It`s not following the wheel speed, so I think driveline ?
Yesterday I noticed a small tear in the shaft boot. Do You think it can be some dust or water going into the bearing, that makes that click sound
Picture enclosed :
Picture enclosed :
driveshaft is directly connected to the wheels (through gears) and the driveshaft rotational speed varies proportional to the wheel/vehicle speed .... so if the click frequency does not change with vehicle speed, it probably isn't the driveshaft
I guess it is possible that there could be a click coming from that joint but I'd look elsewhere first
Eliminator.dk (10/23/24)
hi.
it change with the vehicle speed , but has not the wheel frequency.
Driveshaft Carrier Bearing.
I'm Assuming Still Same Issue From Earlier Thread??
https://themustangsource.com/forums/...d-rear-551307/
While Not Your Exact Problem If and If It Is The Driveshaft a Lot of Driveshaft Info Here. Just an FYI.
https://themustangsource.com/forums/...broken-549501/
Interesting Repair Kit???
https://themustangsource.com/forums/...earing-551193/
Notice All The Different Options These Days For Driveshafts. First One Listed is Original Style But Shows No Boot! Interesting!
https://www.rockauto.com/en/catalog/...ive+shaft,2308
I Don't Know If You Can Get in a Safe Position To Use The Old Wood Trick to Check Carrier Bearing or Not But an FYI. Obviously Car Would Need To Be on Stands!
