2005 GT Driveshaft Prop
Old Oct 23, 2024 | 03:45 AM
Eliminator.dk's Avatar
TMS Denmark S-197 Fan
Hi.
In the last time I can hear a click sound everytime I drive close to a building etc.
It`s not following the wheel speed, so I think driveline ?
Yesterday I noticed a small tear in the shaft boot. Do You think it can be some dust or water going into the bearing, that makes that click sound
Picture enclosed :
Old Oct 23, 2024 | 07:14 AM
Bert's Avatar
driveshaft is directly connected to the wheels (through gears) and the driveshaft rotational speed varies proportional to the wheel/vehicle speed .... so if the click frequency does not change with vehicle speed, it probably isn't the driveshaft
I guess it is possible that there could be a click coming from that joint but I'd look elsewhere first
Old Oct 23, 2024 | 07:38 AM
hi.
it change with the vehicle speed , but has not the wheel frequency.
Old Oct 23, 2024 | 10:44 AM
05stangkc's Avatar
Driveshaft Carrier Bearing.
I'm Assuming Still Same Issue From Earlier Thread??
https://themustangsource.com/forums/...d-rear-551307/
KC
While Not Your Exact Problem If and If It Is The Driveshaft a Lot of Driveshaft Info Here. Just an FYI.
https://themustangsource.com/forums/...broken-549501/
Interesting Repair Kit???
https://themustangsource.com/forums/...earing-551193/
Notice All The Different Options These Days For Driveshafts. First One Listed is Original Style But Shows No Boot! Interesting!
https://www.rockauto.com/en/catalog/...ive+shaft,2308
I Don't Know If You Can Get in a Safe Position To Use The Old Wood Trick to Check Carrier Bearing or Not But an FYI. Obviously Car Would Need To Be on Stands!
KC
MacaRowni
V6 Performance Mods
May 17, 2021 03:47 PM
David Young
Dec 24, 2011 12:54 PM
King Taco
V6 Performance Mods
Oct 30, 2007 10:19 AM
cobra4548
Apr 29, 2007 08:20 PM
