Checklist for Strut/Spring Install...
Old Apr 26, 2012 | 11:18 AM
  #221
Hytek's Avatar
Originally Posted by devildog1679
My floor jack barely clears the Roush splitters. I have to get race ramps or use block to get the front over my rhino ramps. Let me know what your initial settings where at prior to adjustment.
Before I had to drive up on blocks before my rhino ramps too. I'm sure it'll be harder now.
I'll make sure I get a print out of before and after specs.
Another question: Is the phb adjusted with the rear suspension loaded? I can't seem to find a clear answer.
Old Apr 26, 2012 | 12:12 PM
  #222
devildog1679's Avatar
I did mine while rear was on the ramps.
Old Apr 26, 2012 | 12:20 PM
  #223
Hytek's Avatar
Ok thanks. I'll adj it when I put the relocation brackets on this weekend.
Old Apr 26, 2012 | 03:12 PM
  #224
2012GTCS's Avatar
You're doing just the brackets for now?
Old Apr 26, 2012 | 03:26 PM
  #225
Hytek's Avatar
Yeah. Just to see if there's any improvement. If not much than I'll get some lca's.
Old Apr 28, 2012 | 11:01 AM
  #226
2012GTCS's Avatar
Sorry guys, I haven't abandoned this thread just cause I finished the install. Just been hectic with work and some family stuff going on. I'm gonna get on here once I get on my computer and lay out a list of tips and tools and pointers.
If anyone is gonna Be doing the install soon feel free to PM me as I'll get it on my phone and answer whatever I can.
I was shaky prior to doing this but now that I've gone thru the motions I'm pretty confident. It was easy!! (yeah right! Easy to say after the fact lol)
Old Apr 28, 2012 | 11:28 AM
  #227
Went to Firestone and got alignment. Ended up with Left- Camber -1.2, Caster 7.5, Toe .09. Right- Camber -1.7, Caster 7.1, Toe .07. As expected on camber and caster. Not sure why .5 difference b/w sides on camber. I'm ok with the negative camber because my shoulders will see plenty of work with a few track days and autox.
One question, will having a .5 difference b/w sides on camber pose any handling issues? Other than better contact patch on left turns.
Old Apr 29, 2012 | 09:33 AM
  #228
mtnbikefuel80's Avatar
Got my 11+ struts delivered a couple days ago. Did anyone else's come in with the paint chipped off around the spring perch and on the body of the strut? Are they stainless steel? looks like they were rattling around against each other a lot in delivery as the cardboard on the inside of the box was all chewed up and one of the clips came off and a strut was uncompressed. I would add pictures but my phone camera just died. All my pictures are just a full turquoise screen
Old Apr 29, 2012 | 12:34 PM
  #229
Hytek's Avatar
My boxes came in looking like they were kicked around too. Packaging is definitely not their strength.
I'm at Firestone now getting my alignment. I'll post specs shortly.
Old Apr 29, 2012 | 01:58 PM
  #230
Hytek's Avatar
Here's my before and after specs. They also adjusted my phb.
Before:
LF camber -1.3
RF camber -1.4
Toe - .17 R+L total -.35
After:
LF camber -1.3
RF camber -1.5
Toe -.30
Thrust angle before -.06, after 00.
She looks straight now and the rear axle is centered.
Old Apr 29, 2012 | 02:32 PM
  #231
11SHELBYGT500's Avatar
Before:
LF camber -1.3
RF camber -1.4
After:
LF camber -1.3
RF camber -1.5
Toe -.30
You don't like cornering?
Old Apr 29, 2012 | 02:43 PM
  #232
2012GTCS's Avatar
Before:
LF camber -1.3
RF camber -1.4
After:
LF camber -1.3
RF camber -1.5
Toe -.30
So it was pretty good after lowering. Didnt need much of an adjustment it seems.
Old Apr 29, 2012 | 08:16 PM
  #233
Hytek's Avatar
Why do you say that? Is something off?
Only thing that was really off was toe.
Old Apr 29, 2012 | 08:22 PM
  #234
The camber is set more to 0 than I've ever had. Your tires will last longer but for cornering I usually go with -1.7 Are you using CC plates?
Old Apr 29, 2012 | 08:32 PM
  #235
Hytek's Avatar
Ah gotcha. No plates, I bought bolts but didn't use them. Handling seems good so far, however it rained for most of the day so no chance to really get on it.
Old Apr 30, 2012 | 05:03 PM
  #236
Cali_5.0's Avatar
Hytek,
Did they tell you how off-center your rear axle was off before they adjusted your adjustable PHB?
Old Apr 30, 2012 | 05:31 PM
  #237
Hytek's Avatar
Originally Posted by Cali_5.0
Hytek,
I believe it's on my print out at home. I can check when I get home for you.
Old Apr 30, 2012 | 05:44 PM
  #238
way2qk4u2c's Avatar
Joe doesn't understand we live in IL not Cali lol straightest roads in the world.
Old May 2, 2012 | 06:49 AM
  #239
Cant wait to install these parts, just gotta buy the watts link! i hate this axle tramp i get, I want it gone! If i give just a litte too much throttle i think the car is going to shake itself to death
Old May 2, 2012 | 08:35 PM
  #240
Hytek's Avatar
Hytek,
Sorry I forgot to get back to you. Here's the rear specs:
Before
LR TOE - .21
RR TOE - .09
Thrust angle - .06
After
LR - .16
RR - .16
Thrust angle 0.00
