2012-2013 BOSS 302
Drive home
Old 3/21/11 | 07:22 AM
cloud9's Avatar
Originally Posted by PTRocks
The regular 6-gauge oil pressure 'gauge' isn't real. It only has two states, the sender is actually a switch. The LS Boss uses a different sender so that the gauge pack will work properly.
For the V6/GT 'gauge' - see page 413-01-36 of this section of the shop manual. You will see that the gauge is really just an idiot light with moving parts, and the signal comes from a switch and not a sender.
http://iihs.net/fsm/?dir=988&viewfil...g%20Chimes.pdf
So if you buy the gauge pack for a regular Boss do you have to also order a different sender?? I haven't seen that listed anywhere in FRPP's catalog. Ron indicated that we don't even have the switch for oil pressure on the gauge cluster.....
Old 3/21/11 | 08:27 AM
PTRocks's Avatar
I know there is a separate part number for the pressure sender specific to the LS. I have it temporarily listed at the bottom of the Boss parts page, as I don't have complete info on it.
The existing 4-gauge cluster just has the usual idiot light for oil pressure.
Old 3/21/11 | 08:34 AM
cloud9's Avatar
I would have expected some kind of factory sensor/switch. So, there's no gauge depicting H-L for oil pressure, but there is a warning light and possibly chime if oil pressure drops to zero or below a preset psi?
Old 3/21/11 | 08:40 AM
PTRocks's Avatar
Correct. I have also attached the gauge cluster info from the Boss owner's supplement for comparison.
FromZto5
75
10/5/15 02:27 PM
DrisStang
9/14/15 06:20 PM
9/8/15 10:45 AM
dbent15
9/5/15 12:15 PM
Quick Reply: Drive home
