Temperature Gauge
Old Jan 4, 2018 | 01:09 PM
tucsondivots's Avatar
Temperature Gauge
My temp gauge needle (stock analog) usually quickly goes to the left center position when starting the car. Today I noticed that whether the engine is cold or hot, the needle starts at C and slowly creeps to the left center position. Plenty of coolant, no overheating, heater and a/c work fine. Is this the sign of a problem?
Old Jan 4, 2018 | 01:16 PM
SpectreH's Avatar
Is it possible that the thermostat is stuck open? That would make it take longer to warm up.
Old Jan 4, 2018 | 03:01 PM
How would I check?
Old Jan 4, 2018 | 06:44 PM
SpectreH's Avatar
Good question. I'd probably just buy one and replace it, provided it wasn't too difficult.
Old Jan 6, 2018 | 08:40 PM
A bit of an update. Previously, the needle on the temp gauge immediately went to the position just left of center. A few days ago, it started reading all the way to "C" at start and then slowly creeps up to normal temp. Maybe takes 2-3 minutes, tops. The heater works immediately. When the engine is warm, shut off and stared back up, sometimes the gauge immediately goes to the normal temp and sometimes it starts at C and moves to normal within 1-2 minutes. This is also true if I just to the key to run and not actually start the car.
05RedGT
Jan 30, 2012 10:26 AM
48prerunner
Feb 28, 2010 06:35 AM
Error404
13
Jul 24, 2006 08:13 AM
94tbird
20
Sep 7, 2005 10:03 PM
2005 Black GT
Apr 20, 2005 10:35 PM
