Sync/Phone/USB issue?
Old Dec 5, 2010 | 10:00 AM
SD CALSPCL's Avatar
I am not sure what happened yesterday, but I plugged in my memory stick to listen to music, and when I removed it the sync with my cell phone disappeared on the radio face. I have tried to use the phone, but nothing.
I am going to do a master reset today, and start over with the phone, but I was curious if anyone had a similar problem and if it could be related to the USB port use.
I would hate to have to go through this every time I use the USB port.
Old Jan 27, 2011 | 09:32 AM
IT_Guru's Avatar
The only problem I've had is somethimes when I end a call my USB drive won't un-pause. It will just get stuck on pause.
Old Mar 24, 2011 | 02:48 AM
jettdirect's Avatar
Lightbulb Advice
If the memory stick continues to give trouble, try a different memory stick, preferably a brand-name.
If that doesn't help, you might consider an iPhone if you don't already have one. The Sync pairs with the iPhone like they were made for each other. I don't ever have to even touch the iPhone. - I just get in the car and the stereo pairs via bluetooth with the phone automatically, then I can play/pause music using the stereo controls, or take and make phone calls using just the steering wheel controls, again without ever touching the phone or even taking it out of my pants pocket. The iPhone is a very high-quality device which is trouble-free and works like it is supposed to. If you don't have one I highly recommend it.
Hope this helps!
Old Mar 28, 2011 | 02:50 AM
white__stallion's Avatar
I'm not able to use the radio controls with my iPhone via blue tooth for the music. I can use the controls for answering ending and dialing calls. Am I doing something wrong? My iPhone and iPod work great with music and stereo controls when sync is USB.
Old Apr 4, 2011 | 01:56 PM
Big Poppa's Avatar
I had kinda sorta the same problem, it's in this thread
https://themustangsource.com/f803/usb-port-dead-488770/
Old Apr 4, 2011 | 04:27 PM
So Pull fuse 3? I'll give it a shot. Will my iPhone be able to be controlled via Bluetooth as well? Meaning I can change the music via radio buttons rather then my phone or is that just how it works?
Old Apr 11, 2011 | 07:26 AM
FordService's Avatar
Hello All,
I would recommend you to contact the SYNC Support Team at 1-800-392-3673 option 3 for technical assistance.
Deysha
Road_Runner
Sep 2, 2024 04:46 PM
kponypower
Jun 17, 2020 07:17 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
