Power drivers seats
Old Jul 24, 2025 | 09:43 AM
Ridge's Avatar
Power drivers seats
So, apparently my seat slide button somehow got jammed (probably by my leg) in the full rearward position,stuck, would not move. That forward position on the switch is the only action that won’t work. Fast forward to today, I have the seat out and checked the seat motor function at the electrical coupling that goes directly to the seat motor with electrical clips and sure enough, it works as it should. I’ve bypassed all other switches and what appears to be 2 relays side by side under the seat. My question is , can I check these relays before I start buying new ones and throwing parts at it ? WILL these relays fail before a fuse if the switch is jammed in the seat rearward position?
Old Jul 24, 2025 | 10:41 AM
05stangkc's Avatar
Welcome,
I Believe The {Under the seat} Relays are For The Heated Seat Function Only.
See Diag Pdf For All Fuse Locations!
Here are Some 2011 Wiring PDF'S Which May Help!
KC
Might Also Gleen Some Info Here!
Earlier Cars Use Same Track From 07-14
https://themustangsource.com/forums/...o-back-551835/
File Type: pdf
Drive707
Jun 13, 2025 12:56 PM
JustangGT
Dec 29, 2024 01:41 PM
GuyInABlueShirt
Jul 25, 2021 05:59 PM
delz05
05-09 Interior and Audio Mods
Oct 16, 2008 09:48 AM
lodom
May 15, 2005 08:40 PM
