kenwood double din dash kit
Old Oct 23, 2013 | 02:25 AM
  #161
jdub2k5's Avatar
mine is taped up and put behind the radio. The cavity allows for plenty of room to put the RR. I have 3m tape holding it from rattles
Old Oct 23, 2013 | 11:56 AM
  #162
12v Guy's Avatar
Originally Posted by ColSaulTigh
Actually, it says "OBDII Disconnected" not "Disabled".
What firmware is the radio running? You can always try re-flashing the firmware to see if that helps...
We have three states:
No message at top - Working normally or ignition is off.
ODBII Disabled - Comm turned off in setting or setting is Auto and we detect a scan tool.
OBDII Disconnected - We tried to communicate but we received no response. We cannot see any CAN messages. Usually wiring problem.
I would disconnect everything from the OBDII bus and try again. I know it sounds redundant, but please check the wiring again.
Thanks,
Old Oct 23, 2013 | 12:00 PM
  #163
12v Guy's Avatar
Originally Posted by 2014DIB
For those of you that have already performed an install, suggestions on where to place the Maestro RR (required with the new Dash Kit), and perhaps also a SiriusXM SXV200 module? Definitely want to avoid rattles/noises after the install. Also - may need to be able to get to Maestro RR for periodic updates with PC?
Dash Kit arrived today - looks fantastic and completely agree with others - perfect match on the color/finish! At the moment - only wish was could replace the Rear Defog button on the far right with Max AC - almost required year round in Houston! Suspect there may be more "wish list items" - but - initial impression is - was worth the wait! Great job ADS!
Plan to go with DNX 890HD, and add on a back up camera as well.
Program the second function (press and hold) of the rear defrost button to MAX AC. We did not make the first and fifth buttons with replaceable tops because they are shaped differently and we needed to pick two things that EVERY car has.
Cheers,
Old Oct 23, 2013 | 03:09 PM
  #164
ColSaulTigh's Avatar
Thanks,
I was referring specifically to the image he supplied. It says "Disconnected" at the top.
I concur. Even though I don't work for iDataLink, I was trying to say the same thing (politely) - triple-check your wiring job. While possible, it's very unlikely you have a defective Maestro unit if everything else is functioning correctly. Also, check your wires along the entire length - you might have an accidental break in the wire somewhere - splice in some new wires close to the Maestro harness just to verify.
Old Oct 23, 2013 | 03:23 PM
  #165
12v Guy's Avatar
I very much appreciate your helpful and correct responses. I was just trying to explain the messages you can see and what makes them show up. I should have posted in response to his message not yours. Sorry for the confusion!
Cheers!
Old Oct 23, 2013 | 04:06 PM
  #166
arazor's Avatar
12V Guy-I have a question.
My voice button on the steering wheel is programed for one push to access sync voice commands and the continuous hold of the button is programed for phone voice commands but when I press once for the sync voice commands it automatically switches over to my Sync USB 2 and starts playing music, then a few seconds later the voice prompt comes on and says "USB 2" and I have to respnd or it goes through the voice menu. I like it switches to USB 2 but the voice prompt is annoying two seconds after music starts. Any ideas on how to only have one action start when I long press the voice command button?
Old Oct 23, 2013 | 04:12 PM
  #167
arazor's Avatar
(Any ideas on how to only have one action start when I long press the voice command button?)
That should read "Any ideas on how to only have one action start when I single press the sync voice command button."
Sorry for any confusion, I proof read it and still missed the mistake until after I posted it. The long press for sync phone voice menu works fine.
Old Oct 24, 2013 | 10:07 AM
  #168
12v Guy's Avatar
Arazor,
this is a tough question and I will do best I can to answer it. The press on voice (short press) is a command to give Sync Media Player a voice command. In order to process that command, we have to first place the radio and car into the Sync source. That is why the switch to USB (or USB2 or BT Streaming depending on what you used last) happens. Once we know the car is ready to listen to you, the voice prompt comes.
You will notice that if you press the voice button (short press) while already listening to USB, USB 2, Line In, or BT Streaming the prompt will be immediate since we are already in a source, ready to respond.
There is no way to change this functionality. If you want to go to the source, but not via voice, just use the Media button to do so. Short press forward one source in the loop, long press back one source in the loop (unless you changed from default).
Alternately, you can just press the telephone button when the voice prompt happens to cancel it. No need to say anything.
Hope this helps and is clear.
Cheers,
Old Oct 24, 2013 | 07:40 PM
  #169
arazor's Avatar
12V Guy,
Yes very clear and thanks for the response. I didn't think about just hitting the phone button to cancel the voice, I had been just responding with the cancel command. Still a very good system and the more I use it the more comfortable I get with it. Thanks again for the information.
Old Oct 25, 2013 | 12:20 PM
  #170
Finally got around to installing mine - works perfectly - fit is a bit off though - there's a gap between the bottom of the kit and the center console dash that didn't exist with my other (MEtra) kit. I don't see any way of adjusting it either...thoughts?
Old Oct 25, 2013 | 05:35 PM
  #171
12v Guy's Avatar
No way to adjust but weird. We exactly matched the shape of the OEM panel so fit should be exactly the same. Do you know if you had same gap with OEM?
How are all the features working out for you??
Thanks,
Old Oct 25, 2013 | 05:45 PM
  #172
Gonefission's Avatar
Just got the kit installed today and I also have the same gap at the bottom. This doesn't particularly bother me, and I can't remember if OEM had the same issue.
So far I am loving this setup.
Old Oct 25, 2013 | 06:22 PM
  #173
Thanks,
I will pull the OEM panel and take some pics/measurements. I won't be able to do this until Monday - I have a busy weekend.
Old Oct 25, 2013 | 06:24 PM
  #174
12v Guy's Avatar
Thanks for the pic. Glad you like!
Cheers,
Old Oct 25, 2013 | 10:20 PM
  #175
jdub2k5's Avatar
I also have the gap at the bottom we just fixed it using a piece of stick on foam that comes in a roll
Old Oct 25, 2013 | 11:59 PM
  #176
Beginning to see a trend here - I wonder if the 1st batch maybe had some QC issues coming out of China - if the gap were small, I wouldn't complain, but it's large enough to see through, and you can see the two tabs at the bottom through it. Again, I'll take some measurements with my calipers, but would like to know what iDataLink will do should this turn out to be an issue that's not easily fixed.
Old Oct 26, 2013 | 04:53 AM
  #177
EastTNMustang's Avatar
Here's a pic of my oem panel in place...there is a gap at the bottom. I'm installing the kit later this week and will take some after pics to see if there is a difference.
Old Oct 28, 2013 | 09:03 AM
  #178
12v Guy's Avatar
All,
We are double checking our stuff, but we are pretty sure the dimensions match. If we have issues, we'd try to resolve them so you are all happy. We strive for 100% happy customers. I am interested in jdub2k5's solution as I think he may have done what we think will work. It is might be possible to shim up the bottom panel with some foam tape underneath.
FWIW, these two gaps look very similar and we do know for sure there is some slop in the OEM panel.
Attached Thumbnails kenwood double din dash kit-image-3064564552.jpg   kenwood double din dash kit-img_20131025_131457.jpg
Old Oct 28, 2013 | 05:25 PM
  #179
arazor's Avatar
12V Guy,
I am really missing not having the time displayed on the Sync screen. I'm sure you looked at this but if we had the Sirius aftermarket module installed could you pick up a time signal off that to display through the Maestro unit on the Sync screen?
There's got to be some way to get Kenwood to pass the time function to you guys. For all the technology built into these units a very small request.
Maybe some one will root the H/U soon.
Old Oct 28, 2013 | 05:55 PM
  #180
jdub2k5's Avatar
Foam tape fixed mine
