kenwood double din dash kit
Old Nov 2, 2013 | 01:59 PM
  #201
Automatic 5.0's Avatar
Originally Posted by 14rs3roush
Finished my install today...everything works great. Here are a few pics.
How much did everything cost? I have a base stereo in my GT but eventually want to upgrade it.
Old Nov 2, 2013 | 02:02 PM
  #202
EastTNMustang's Avatar
It was about $1200 for everything, including the antenna adapter so I could keep my OEM radio antenna.
Old Nov 2, 2013 | 04:08 PM
  #203
2014DIB's Avatar
Any details on the antenna adapter? Is it the Metra 40-CR10?
Old Nov 2, 2013 | 07:14 PM
  #204
Yes...it's the Metra...Autozone used the AW-CR10 part number, or 40-CR10 may be the same.
Old Nov 2, 2013 | 10:44 PM
  #205
2014DIB's Avatar
Thanks Ron!
Will be sure to pick one up at Autozone.
Waiting on a good deal on a DNX890HD - although it appears a lot of the on-line reviews are not favorable on the 890 and even 990.
Old Nov 3, 2013 | 04:31 AM
  #206
Thanks Ron! Will be sure to pick one up at Autozone. Waiting on a good deal on a DNX890HD - although it appears a lot of the on-line reviews are not favorable on the 890 and even 990.
Yes...I saw many of the reviews, but I think several of those reviews were from when the unit first came out last spring/early summer...recommend you ensure your HU is updated with latest firmware as soon as you power it up. The latest firmware speeds up the unit and fixes some of the Nav quirks.
Also, a lot of people complained about the screen being too bright at night...it's not in the manual, but there's a back door feature that allows you to dim the night screen much more...do a google search and you'll find a YouTube video by Dimer. It's a simple process and he does a good job of explaining how to perform the function.
I'll let you know if I run into any other problems.
Old Nov 4, 2013 | 02:43 AM
  #207
jdub2k5's Avatar
I own the 890 and I will never buy one again I cannot stand how hard it is to you I would go with them Lois model that works with I data and has digital gauges
Old Nov 4, 2013 | 02:44 AM
  #208
jdub2k5's Avatar
my phone types what it wants I meant to say I would go with the cheapest model because majority of the features I do not use ort have no idea how to use
Old Nov 4, 2013 | 03:44 AM
  #209
The 890 does have a lot of features and I may not use all of them, but it's nice to play around with the unit to see what it offers...it can be overwhelming.
Old Nov 4, 2013 | 07:36 AM
  #210
Gonefission's Avatar
I have had no issues with my 890 thus far. It hasn't locked up and all the features seem to work just as advertised. I am a gadget guy and love all the features the 890 offers. I would buy this again, no question.
Like 14rs3roush said, just make sure you have the newest software on the unit.
Old Nov 4, 2013 | 08:02 AM
  #211
Tiger-Heli's Avatar
More info
Originally Posted by 12v Guy
FWIW, we do more with the secondary screen than any other interface. We keep it alive, put data from head unit there. Everyone else removes it or makes it go mostly dead.
Absolutely - big advantage - other kits I've seen either show "SYNC - LINE IN" or time/calendar continuously.
That isn't really the issue - the DDX370 will work with Idata and I'd assume will have the digital gauges. However, it might not be easier to use and it doesn't have the separate Sirius port, so you would have to skip Sirius or use a PnP unit like the XM Onyx.
Old Nov 5, 2013 | 07:00 PM
  #212
arazor's Avatar
Smile
Thanks, your link to the video worked on my 770HD-so much better!
Old Nov 5, 2013 | 07:04 PM
  #213
arazor's Avatar
Originally Posted by Gonefission
I updated my DNX890HD boot screen using this video, the same button combo might work with the 770.
http://www.youtube.com/watch?v=fFU4MpvCoio
Thanks, used this video on my 770hd to access the same boot screen he did. Now i just have to experiment with picture format and size and try to load one. You guys on this forum have been a great help making my H/U more enjoyable. I appreciate it.
Old Nov 5, 2013 | 08:01 PM
  #214
ColSaulTigh's Avatar
If you'd like to change the boot screen here is what you need to do:
Step one:
USB with Fat32 format
Set your input on your iPod to AN-IN2
Create your image - Pixel Size should be 800 * 480 / Save as 16 bit Full Color BMP and the setting of RGB of R5,G6,B5 <-- important
Put your image on your USB drive and plug it into the iPod connection
Step two:
Press and hold (do not let go!!) Volume Down + Power
Press the red triangle (with a pen - your finger will not work) and release (still holding onto Volume Down + Power)
Wait for the device to boot completely and do not let go until the buttons illuminate.
Step three:
Select OEM Image
Select the image you have on your USB key*
Old Nov 5, 2013 | 08:21 PM
  #215
...and if you want to change the screen brightness:
http://manual.kenwood.com/ce/im365/N...SettingUp.html
Old Nov 6, 2013 | 05:37 AM
  #216
Tiger-Heli's Avatar
Thanks!!!
I don't see a way to embed video on the forum (lookee there - it did it automagically), but why make everyone search (and technically, it's not a video by dimer - its a video by f14av8r with dimmer misspelled as Dimer in the title):
To change the startup screen:
Old Nov 6, 2013 | 05:41 AM
  #217
Originally Posted by Tiger-Heli
Thanks!!! I don't see a way to embed video on the forum (lookee there - it did it automagically), but why make everyone search (and technically, it's not a video by dimer - its a video by f14av8r with dimmer misspelled as Dimer in the title): Video Link: http://www.youtube.com/watch?v=W99Zp7UzCmA To change the startup screen: Video Link: http://www.youtube.com/watch?v=fFU4MpvCoio
That's a great help to everyone...I couldn't post the video link. Still learning how to use this forum.
Old Nov 6, 2013 | 05:42 AM
  #218
Tiger-Heli's Avatar
No problem - I wouldn't have known the Video was on YouTube - so that evens things out ...
Old Nov 6, 2013 | 05:50 AM
  #219
Too funny
Old Nov 6, 2013 | 05:30 PM
  #220
arazor's Avatar
I went through the manual several times and still missed it, **** that's bad, I'm getting old.
