Installed new front speakers
The Shaker systems have one or two amps for the front subs (early builds had separate amps for left and right, later builds have one amp for both sides) mounted at the left end of the dash. I can't tell from the schematic if they are in the lower part of the dash or behind the upper left kick panel.
My schematic for the rear sub amp in the Shaker 1000 has only a bunch of pointers with no labels but my best guess is that it is behind the left quarter trim panel near the rear seat.
My speakers are 2,184.93 miles away but are on their way to Tennessee . I ordered 4 Pioneer TS-D6802R. They were just a little over half the price of two speakers from Crutchfield. Looks like i will have to remove the rear seat and side panels to install the rear speakers. I'm not looking forward to that. They should be here sometime on the 10th. Can't wait to install them.
I just replaced the two fronts with those exact pioneers... Don't bother with the backs.
It took 10 minutes a door (got the 7mm socket and 30 torx bit at Lowes yesterday). Just went for my first ride..... AMAZING.... completely different radio... It used to sound so muffled.
I'm SO HAPPY RIGHT NOW!!!!!
I had all my speakers replaced a couple weeks ago. They sound a lot cleaner then the stock ones.
This is what I got:
Front: JL Audio - VR525-CSi Component
Back: JL Audio - TR570-CXi Coaxials
http://mobile.jlaudio.com/products_c...php?comp_id=61
http://mobile.jlaudio.com/products_c...hp?comp_id=116
This is what I got:
They sound much crisper and cleaner then the crappy stock speakers. They add more bass, but the system could use more.
I replaced 4 speakers yesterday with the Pioneer TS-D6802R. The door speakers for the Shaker 500 are a joke. They looked like toy speakers for a child . 50W and made in Mexico. The rear speakers look a little bit better but they are 25W and made in China. My new speakers sound so much better than the old ones. I now have my 'fade' adjusted so i hear a 'hint' of the rear speakers. I'm happy Another up-grade i wouldn't have known about if it weren't for this 'Great' Forum
I watched youtube video's on it about a million times There is a difference between the 2011's in videos i saw. The videos were for 05 to 09 Mustangs, but overall close enough to get you started. The rear speakers are screwed down with hex head screws making them easier to remove. You have to be 'very' careful removing the panels. I put a few small scratches on a couple panels but i think i can fix them .
I might need to research but last I checked, the Amp, or at least with the Kicker set up the amp is up behind the dash on the passenger side. I could be completely wrong though.
I have to add; I didn't remove the door handle cable on the front doors because the door panel tilted out and gave me plenty of room to do the door speakers. Lay something soft (towel) under the door panel just in case it slips off the door. One of mine did and one didn't.
I picked up a set of Boston S85s today and went to install them.
I hadn't realized I would need a harness to make these work...don't feel like hacking the connector on the stocker.
Just had to reinstall the stock speakers!
Thanks for the part number on the harness...2 to 7 days until I hear these babies.
http://www.crutchfield.com/p_107DXI5...tml?search=dxi
Looking at picking up four of those to replace the stock speakers. Thoughts?
I've purchased many times from here http://www.sonicelectronix.com
I'd spend a little more to get better front speakers and don't bother with the rears.
When im doing my install- im going with these
http://www.sonicelectronix.com/item_...+C3-570CW.html
you can mount the tweeter on the woofer itself to save space- plus you get a 5x7 bass out of it and component filtering which is sweet.
