Adding the OEM nav
Old May 27, 2014 | 06:56 PM
  #421
jim010's Avatar
First off, you will need to change out the climate harness or your A/C will not work properly. See the posts at the beginning of the thread.
Since you did an aftermarket amp, I can't help you there, but hopefully the tech support for the aftermarket amp might help.
Hopefully not the dash harness, it's not something I want to do on my day off again... Ever
lol ... I hear you there!
The only issue I can think of besides the ACM being wonky (which I doubt) is that maybe you did get the wrong harness for your car? But likely you need to look at your speaker wires - probably tapped into the wrong places?
Old May 27, 2014 | 07:03 PM
  #422
zeroaviation's Avatar
I think he also got the incorrect HVAC module.
-Matt
Old May 27, 2014 | 07:06 PM
  #423
jim010's Avatar
-Matt
Well between that and then changing the climate harness, your A/C problems should go away.
Old May 27, 2014 | 07:15 PM
  #424
Mustang30's Avatar
Aaahhhh man, ok so what has to come out for that? Are we talkn full dash, or reach around from a airbag and vents?
Old May 27, 2014 | 07:18 PM
  #425
jim010's Avatar
You don't have to take out the dash for this one. You can just crawl under the passenger side, take off the glove box and switch it out. The harness is not expensive. Part number is posted in the beginning of the thread.
This will not give you dual zone, but it will get A/C working right along with that climate module you have coming.
Old May 27, 2014 | 07:25 PM
  #426
LEXiiON's Avatar
Well, I disagree. I had to pull the dash for the climate control harness, as it routes behind the evaporator housing. No chance to get there with the dash in place.
LEXiiON
Old May 27, 2014 | 07:27 PM
  #427
jim010's Avatar
I routed that wire in front of the housing instead of the back.
Old May 27, 2014 | 07:32 PM
  #428
LEXiiON's Avatar
How did you get those two tabs in the back loose? Did you leave the old harness in place?
LEXiiON
Old May 27, 2014 | 07:36 PM
  #429
jim010's Avatar
I left the part of the harness that goes in behind the evaporator in there and just cut out the connector and the rest of the harness.
When I pull out the dash in the future to put in dual zone, I'll route it through the back.
Old May 27, 2014 | 09:01 PM
  #430
Mustang30's Avatar
Is the dash really a two person affair or can one person handle it. Also does it have to come all the way out for the climate harness or can it be lifted up and worked around? I just get the feeling Ill end up with a dash rattle if it has to come out
Old May 27, 2014 | 09:26 PM
  #431
jim010's Avatar
It is most definitely a 2 person job. No question. You didn't already pull it out once to put in the new dash harness?
And you absolutely do not need to pull it out, not even partially, to put in the climate harness. Lex was saying that he pulled it out because 1 part of the harness goes around behind the evaporator unit and plugs into it on the driver's side. You cannot pull out the old harness cleanly because it is clipped in there behind the evaporator. You can just cut the old harness at the point where it goes in behind and leave that part back there. The rest of the harness is accessible from under passenger side - no issues there. When it comes time to plug in the connector that goes to the driver's side, you won't be able to route it behind the evaporator, like the old harness. So just route those wires in front instead.
Old May 27, 2014 | 09:33 PM
  #432
Mustang30's Avatar
Understood thanks, anybody in the chicago area want to help troubleshoot my radio issues?
Old May 27, 2014 | 09:45 PM
  #433
jim010's Avatar
I'm looking at the pinouts for the connectors for the nav vs non nav cars on the hvac module. There are many differences with a few pins switched places between the two.
All should be good on that front when you fix that.
Also, without the new switch on the right side of the wheel, the phone button will not work. Part number is posted in the first page of this thread for you.
Good luck with the speakers. Not sure what is going on there.
Old May 28, 2014 | 11:59 AM
  #434
Mustang30's Avatar
Just ordered the missing parts for ac, I'll update you guys Monday
Old Jun 2, 2014 | 05:56 PM
  #435
Mustang30's Avatar
Ok so I received the ac harness, but now on the drivers side I have an extra black plug... 4 pins with red locking clip. Any ideas where this might go? The old one didn't have it, just a grey plug.
Old Jun 2, 2014 | 07:59 PM
  #436
jim010's Avatar
That extra plug is supposed to go into the second blend door of the dual zone climate control unit. Which you don't have. It doesn't go anywhere.
However, in the future, you might want to get the dual zone unit. I'll be getting it in the near future.
Old Jun 2, 2014 | 09:30 PM
  #437
Mustang30's Avatar
Thanks bro, I kind of figured that but wasn't to sure. Wrapped everything up and it works great. No more driving around with the defroster on....not fun! I'm still waiting on the acm. Hopefully this week the shop will be done with it
Old Jun 2, 2014 | 09:34 PM
  #438
jim010's Avatar
ACM? What is wrong with it?
Old Jun 2, 2014 | 11:14 PM
  #439
Mustang30's Avatar
Only getting one channel of output i.e. Front right speaker
Old Jun 11, 2014 | 04:16 PM
  #440
Mustang30's Avatar
So I got the acm back from the shop...it checks out good. However I'm still only managing to get sound from one or two speakers the most. I've changed the pins in my rig to match the factory harness, no joy, changed the factory stuff to match the schematics, no luck there either. Not sure what's going on here. I did notice that the new harness has speaker output pins in different locations than the previous harness. Where else in the car will I have to change pins in order to get all 4 speakers working?
