'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old 4/11/13 | 12:03 PM
  #221
11SHELBYGT500's Avatar
Does anyone really use those apps? I never see any posts about them.
Old 4/11/13 | 12:17 PM
  #222
zeroaviation's Avatar
lol... Good thought! I just think the LCD looks cool myself.
Old 4/11/13 | 12:22 PM
  #223
Steven's Avatar
Yeah, I like the look of the LCD. If we can get it all working with Cruise Control I'd be happy.
Old 4/11/13 | 12:28 PM
  #224
It will happen. Just will take some patience, and finagiling. Luckily Jim has a dealer and a tech that will work with him. If you didnt have a cool dealership you would need a external microcontroller or VCM.
Old 4/11/13 | 12:31 PM
  #225
dmhines's Avatar
I have a friend that is a Service Rep at my local dealer. Once Jim's tech figures it all out and lets us know what he did .. I will have no problem getting my car properly "hacked" to get it all working. The tech will just do what my buddy tells him to do.
Having Track Apps working is a bonus ... I want Cruise to work .. and it would be nice to get the correct OBD data on the bus so the extra gauges in the LCD display work.
Old 4/11/13 | 12:39 PM
  #226
jim010's Avatar
If you are all waiting on me, I have to find a time I can get it to him.
I will need to wire up the switch before I take the car down, though. They will need it working right to check the cluster.
We are close now!
Old 4/11/13 | 12:43 PM
  #227
dmhines's Avatar
We are close now!
Appreciate it!! I'm gonna hold off on the PATS relearn until your tech gets everything figured out.
Old 4/11/13 | 12:45 PM
  #228
dmhines's Avatar
We are close now!
I should have my 2013 wheel tomorrow with the 2013 harness so all my buttons will be wired correctly going to the clockspring.
Old 4/11/13 | 12:53 PM
  #229
jim010's Avatar
So all you will need is to change and add pins on the dash side of the clockspring then.
On a side note, the buttons on the 2013 switch are painted more of a flat black compared to the satin black on the 2012 switches. In otherwords, the paint on the left swtich from the 2013 doesn't match the right switch on 2012.
Old 4/11/13 | 12:57 PM
  #230
dmhines's Avatar
I don't see any change other than 3 and 11 and I already moved the setup wires to pin 3 and 11.
2012
-to the clockspring (c2274a)
Pin 1 - airbag driver 1
pin 2 - airbag driver 2
Pin 3 - unused
Pin 4 - switch Audio w/ SYNC 2 -
Pin 5 - ground cross car beam
Pin 6 - switch Audio /w SYNC 2 +
Pin 7 - unused
Pin 8 - horn
Pin 9 - airbag driver 1
Pin 10 - airbag driver 2
Pin 11 - unused
Pin 12 - switch audio 1 -
Pin 13 - switch audio 1 +
Pin 14 - cruise control command return
Pin 15 - cruise control command
Pin 16 - illumination
2013
Pin 3 - switch info
Pin 7 - unused
Pin 8 - horn
Pin 11 - switch info
Old 4/11/13 | 01:04 PM
  #231
jim010's Avatar
You are good, then.
I'll be wiring it up properly tonight. I'l let you know if the cruise control is fixed.
Old 4/11/13 | 01:11 PM
  #232
jim010's Avatar
You are good, then.
Old 4/11/13 | 01:38 PM
  #233
jim010's Avatar
To get the odo reading changed.
Here is the form that needs to be filled out and sent with your cluster to United Radio in New York. They charge $85. Shipping is on top of that.
File Type: pdf
Old 4/11/13 | 09:10 PM
  #234
jim010's Avatar
Just a heads up:
The diagram and pin order for connector 2998 that Ford has in its Mustang wiring diagrams for 2012 is WRONG.
I have double, triple and quadruple checked. No doubt. For those who think I'm an idiot and can't read a wiring diagram, I have used Ford's diagrams to retro fit heated seats, passenger power seats and ambient lighting in my 2005, and I used their diagrams to retro fit the OEM nav and amp.
Connector 2998 for 2012 year - the one that actually plugs into the switch is wired the same as the 2013. The only difference is that the wire that plugs into pin 2 in the 2012 year goes into pin 1 in 2013. That wire is for the signal return for the cruise control.
I'm wiring it up now.
Old 4/12/13 | 12:23 AM
  #235
jim010's Avatar
Cruise doesn't work for me. The cruise symbol doesn't light up either.
Old 4/12/13 | 05:13 AM
  #236
dmhines's Avatar
Bummer. Didnt thread on other forum say it kinda worked?
Old 4/12/13 | 07:59 AM
  #237
Steven's Avatar
Could it be the voltage difference mentioned earlier in the thread?
Old 4/12/13 | 08:19 AM
  #238
jim010's Avatar
I have no answers at this time.
Old 4/12/13 | 08:42 AM
  #239
jim010's Avatar
Finding the diagram for the connector was wrong in the book threw me for a loop. It is possible that the 2013 diagram is incorrect too. The ground and illumination are in the right sopts, though. And you already tested the direction and ok buttons, so they are located in the right spots. There's only 2 spots left and it has to be for cruise. Voltages must be different. PCM flashing looks to be the only option here. That or just put the switch somewhere else and keep the old cruise switch.
Old 4/12/13 | 09:05 AM
  #240
dmhines's Avatar
Jim ... let see how you make out with the Tech at your dealer ... but I came up with this simple solution if the tech can't get everything working.
Keep all the 2012 buttons on steering wheel and Setup buttons. I already confirmed the 2012 setup buttons can to UP/DOWN/LEFT/RIGHT ... with only the OK button missing.
TO create an OK button we just need to splice a momentary switch into the wires coming out of pin 5 and pin 4 on the 2012 setup switch. The OK resistance is 2.110K as per your charts. So coming off the wire on the momentary switch we just need to add the appropriate resisters and WALA .. we have all switches working and an OK button too. I would put the OK button underneath the 2012 setup switches. The 2012 cruise buttons would stay on the steering wheel.
I think in this scenario we would still need to put the AS BUILT data from the 2012 into the 2013 cluster so make sure the Cruise LIght works.
Quick Reply: '13-14 Cluster into '10-12 car (with TrackApps) retrofit
