'13-14 Cluster into '10-12 car (with TrackApps) retrofit
#2201
#2202
#2203
#2204
I did last night I started a new session then when I got to the screen to confirm my vin I put in a 2013 then I went to PMI the ABS and asked to confirm the vin I said it was the wrong vin and put the same 2013 vin in. Then I had to go manually download the calibration files but It said the the operation was completed successfully. the I did the yaw calibration that went fine as well but my abs light was still flashing and my traction control and advancetrac lights are still on so I tried to clear a CDTC It cleared a lot but I still had one for abs that was incompatible software I believe it was code 57 or 51 can't remember.
#2205
I just brought the car to the dealership today and I did not get any progress on this I sat down with the tech and we PMI'ed the ABS and I still had DTC code 57 Incompatible software on my cluster so does anyone have zero's phone # where I can give him a call and try to troubleshoot this?
#2206
https://themustangsource.com/forums/...1/#post6760842
#2207
Its good to hear from you my friend and I bought a used 2014 module eBay listing:http://www.ebay.com/itm/171236733701?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT and it says it PMI's successfully but the code is still there so far I have my SJB, IPC, PCM flashed successfully and are working its just the BCMB and ABS that are not working BCMB gives me a module config failed error when i try as-built and abs is well the problem I am trying to fix now. do I need to do my BCE module too or is that the same as the BCM?
#2210
Dan sadly this did not work I used a vin from a 2014 VIN: 1ZVBP8AM2E5245359 but I still had code 57 on my screen could you pm zero's number so I can try and call him and see if he can shed some light on this?
#2213
#2215
Got this finally working and a bonus for v6 users it unlocks advanctrak sport mode! But I got the new module from tasca parts for about $200 and took the Vcm II originally I ran a 3.9s 0-30 but then I turned the sport mode on and I ran a 2.8s! Here is a pic and no DTCs
2.8!
2.8!
#2216
is there a harness anywhere that would connect to the factory RGB controller for ambient lighting/my color?
Ford uses the "common cathode" RGB LED lighting and so since I have a trackapps cluster now and changing colors on the cluster works like its supposed to, i know that to change the "my color" i would need some more stuff to add the factory ambient lighting... HOWEVER, RGB common cathode LEDS are all the same, you've got a positive (R)ed (G)reen (B)lue wire and a negative ground. So i've wired up my ambient lightning (factory harnesses and cup holder ring etc) to an aftermarket controller which works fine but its controlled by a little IR remote rather than by the cluster. If i could find somewhere in the dash that a harness WOULD connect to for the RGB i could run that into an RGB 12v LED amp then back out to all the LEDs.
***edit***
I meant to post this on the other post "retrofit trackapps cluster"
My current setup
***edit***
My current setup
#2218
well, my aftermarket rgb controller works quite well i guess! Just wanted a more of a factory setup!
I have all the factory ford OEM lighting its just that its controlled by an aftermarket controller. Whats cool is that when the car is off, its that cyan blue/green color or (ice blue) or whatever ford calls it. then when i start the car it turns red and red is much easier on my eyes at night and matches the settings ive got on my cluster.
#2219
okay good to know! I meant to post this on the other trackapps thread! i didnt realize this one said 10-12 cars lol.
This is how it's wired to the BCM (the module in the trunk - passengers side)
LEXiiON
#2220
