Need advice on springs
Old Aug 9, 2012 | 08:42 AM
mikeyt03's Avatar
I am about to get springs, and shock/struts and Im kind of torn. I want to go with something lower than 1 inch, but I'm not sure what springs would give good enough drop with my tire size. I have 295-35-20 in the rear and 255-35-20 in front and I was thinking that a 1.5 drop in the rear would be perfect. I might go with steeda ultra lights and either steeda shocks and struts or koni srt. I looked at frpp k springs but it says they drop 1.5 in front and rear, which would leave the front looking higher than the rear. Opinions and pics welcome.
Old Aug 9, 2012 | 04:10 PM
Brandon302's Avatar
Have you checked to see if a drop that low will require you to relocate the swaybar and LCA?
Old Aug 9, 2012 | 04:48 PM
choate's Avatar
You would be happy w/ Steeda Ultralights, Eibach Pro Kit, or BMR springs. The K springs lower it the same all the way around so the back will stay higher than the front.
Old Aug 9, 2012 | 06:43 PM
tj@steeda's Avatar
Here is another site with some great pictures of a consumer's car that we recently put the ultra lites on.
http://www.stangsofsouthflorida.com/...ghlight=Steeda
If you like what you see then PM and I can start putting together a forum discount/package deal for what you are looking for.
Let me know.
Best Regards,
TJ
Old Aug 10, 2012 | 07:55 AM
mikeyt03's Avatar
Let me know.
Best Regards,
TJ
Sent you a pm.
Old Aug 10, 2012 | 09:14 AM
blackbeard's Avatar
I will be going with ultra lites and their adjustable panhard once my car finally comes in.
Old Aug 10, 2012 | 10:00 AM
mikeyt03's Avatar
I like the spring rate of the sports better, but it looks like the ultra lites lower just a bit more due to the softer spring rate. Kinds torn between the two.
Old Aug 10, 2012 | 02:43 PM
SteedaBrandon's Avatar
Former Vendor
Is this your daily driver? Do you track it?
Old Aug 10, 2012 | 06:19 PM
mikeyt03's Avatar
It's my dd.
Old Aug 13, 2012 | 03:30 PM
Former Vendor
It's my dd.
If it's a daily driver and you aren't tracking it, I would definitely go with the Ultralites. They have a slightly softer front spring rate (5lbs less) and are about the same drop amount. And they're ~$10 less.
Let me know if I can be of any assistance with those.
Old Aug 14, 2012 | 10:26 AM
tj@steeda's Avatar
Mikey,
Just wanted to make sure you received the information you requested via PM. Let me know if you have any questions or need further information.
Best Regards,
TJ
Old Aug 14, 2012 | 08:21 PM
mikeyt03's Avatar
Sent you a pm reply.
Old Aug 20, 2012 | 11:11 PM
brewsky54's Avatar
I love my Eibach Pro Kit. Absolutey perfect for a DD.
Old Aug 21, 2012 | 12:29 AM
cpotts13's Avatar
My friend has the h&r race springs, Koni str.t shocks and struts. Also, you will need an adjustable panhard bar and lca relocation brackets.
Old Aug 21, 2012 | 05:00 PM
Tight Lines's Avatar
I'm very happy with my Koni's with Steeda sports. I have 19" wheels for reference. This is my dd as well.
Attached Thumbnails Need advice on springs-image-2019313518.jpg   Need advice on springs-image-2178596190.jpg
Old Aug 21, 2012 | 08:19 PM
Jetag93's Avatar
I have H&R super sport springs with stock struts and shocks for the moment.
Attached Thumbnails Need advice on springs-image-1208626807.jpg   Need advice on springs-image-2132562122.jpg   Need advice on springs-image-1901575949.jpg
Old Aug 24, 2012 | 05:59 AM
tbone004's Avatar
Looks good, this is the way I am thinking of going. Did you have to change anything else to get it aligned with in factory specs?
Old Aug 24, 2012 | 09:55 AM
BackinBlack13's Avatar
Can you post a side pic?
Autotooner
Nov 24, 2017 12:42 PM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
