Mustang 3.5L Ecoboost engine swap
Old Aug 9, 2015 | 07:59 PM
  #161
sqidd's Avatar
Originally Posted by MTXPERT
The stock DI injectors have supposed 600WHP on a SHO done by Livernois on C16. I would rather run E85 so it will require aux fueling.
How do you trigger/run/tune the aux injection?
Old Aug 9, 2015 | 08:03 PM
  #162
Ecostang's Avatar
Originally Posted by TimeWarpF100
Someone recently posted on my build thread that computer mod is now avail to do just that.
Ford Performance told me a couple weeks ago performance pak for sure avail in october, finally a set date. ( but have heard that for nearly 6 yrs now)
http://www.garagejournal.com/forum/s...d.php?t=147380
They told me August 1st, then last week they told me the end of the month. They will eventually have it, I'll wait and complain haha. If I jump the gun and try something else I may regret it, could work or it could be a costly mistake.
Old Aug 9, 2015 | 08:07 PM
  #163
MTXPERT's Avatar
I'm looking at the microsquirt, I used something else previously.
Just need something that can read boost and rpm and create a fuel map, easy peasy. The hardest part is the factory ECU is WB closed loop, even at WOT it's closed loop. The factory ECU see's the additional fueling in LTFT and starts pulling fuel after awhile. Recently tuners have been able to to make it go open loop at WOT to stop this. E85 spraying in the intake tract is also a great way to cool off IAT...
Old Aug 9, 2015 | 08:14 PM
  #164
sqidd's Avatar
What a PITA, LOL!
Old Aug 9, 2015 | 08:27 PM
  #165
Ecostang's Avatar
From the pictures I have seen you need to modify the PS valve cover to be able to mount the second HPFP. I'm not sure if there is something special about the cam that runs it. Checking that out would be as easy as popping your valve covers and checking. The DS cam already runs the HPFP. If the PS is the same you're in business.
Roush makes their own valve cover for the PS. Looks like a billet CNC job from the pics. No reason you can't mod the stock plastic one though. All you would be doing is adding a mount.
Just FYI I tracked down the guy in charge of the Roush setup, the injectors are $1500 each and you have to do custom cams with a DI pump lobe.
I did a ton of research in trying to do that as well, it's not cost effective for a small run or a one off.
I've spent 2+ years trying to figure a way for the factory DI setup to have enough flow for 1K HP, it can't happen. You know this because the GT and supposedly the new Raptor are gong to both PFI/DI like my Flex had.
I defintely don't have $9k worth of injectors and a custom cam in the budget, cool idea though.
Old Aug 9, 2015 | 08:35 PM
  #166
Ecostang's Avatar
Geoff mentioned this...
http://www.adaptronic.com.au
Or the mega squirt which Mike also mentioned
Old Aug 9, 2015 | 09:23 PM
  #167
Ecostang's Avatar
About the transmission swap from auto to standard. I read more about it, I need a wiring harness for manual trans and a ecu for manual to make it work. That's what I'm getting with the ecoboost control pack, ecu and a wiring harness for a manual. Question is will the ecoboost wiring harness include the clutch pedal sensor hookups? I also read that a bypass harness is needed for the automatic shifter position sensor, probably a non-issue with the ecoboost control pack.
http://www.mustangandfords.com/how-t...smission-swap/
Old Aug 9, 2015 | 09:37 PM
  #168
TimeWarpF100's Avatar
Originally Posted by Ecostang
Thanks, I actually read your entire build thread a couple months ago. It's soooo long! I was wondering when you would be getting back to work on it, great to hear. A truly ambitious project, much more involved than the mustang. It will be impressive when you pull it off, not to discount what you accomplished already. Welcome and feel free to drop in a link to your build thread, I'm sure there's some people here that might like to cruise it.
For the EcoF100 Project
Pages 1-14
Pages 44-76 or Posts 877-1515
Page 93 thru current starts back again.
A lot going on in between.
Pretty much posting the basics. Would take far too long for every detail.
Early Pages here:
Then starts again page 44 post 877
http://www.garagejournal.com/forum/s...147380&page=44
Thru Page 76 post 1515
Current is page 93 post 1842 thru today
http://www.garagejournal.com/forum/s...147380&page=93
Really looking forward to seeing the Mustang EcoSwap completed.
I sent a email to HP Tuners to see what they have to say.
Old Aug 11, 2015 | 01:08 PM
  #169
GLOCKer's Avatar
I joined this forum just to subscribe to this thread!!! Very neat build! I hope FRPP gets that control pack on the market for you soon!
Old Aug 11, 2015 | 06:49 PM
  #170
Ecostang's Avatar
Welcome!
Old Aug 11, 2015 | 06:55 PM
  #171
Ecostang's Avatar
I pressure tested the manifold today, had 2 small leaks that will need to be fixed. No big deal, but I'm glad I tested it. I used soapy water and 50 psi to test it.
I've been busy lately so not much progress on the car to report. However I did order a 3.73 2012 mustang rear end with 30k miles, hard to find them with factory 3.73s that aren't really expensive. I also ordered borla 3" mid pipes (over axles) and 3" x pipe, all that should arrive this week. I'll probably have custom pieces made to attach the x pipe to the exhaust manifolds, there will be a couple 3" cats installed in these custom pieces.
Old Aug 11, 2015 | 06:57 PM
  #172
Ecostang's Avatar
Rear end
Old Aug 12, 2015 | 04:57 AM
  #173
sqidd's Avatar
Rear end
Where did you source the rear end?
Old Aug 12, 2015 | 08:02 AM
  #174
Ecostang's Avatar
The partsfarm on eBay, I paid $700 for it where most salvage lots with factory 3.73 rear end are asking $1k-$1,300. I had 3.73 gears put in my Shelby last year and paid $1,100 for the work and gears......to pay $700 for an entire rear end with the right gears seems free.
I have bought nearly all of the parts for this car on eBay, engine, trans, intercoolers, exhaust, etc., lots of gt500 take-off parts from Shelby America on eBay.
Old Aug 12, 2015 | 08:15 AM
  #175
sqidd's Avatar
Cool. I need to build another rear end with 3.31's for the Texas mile. I'm looking for a cheap core.
Old Aug 12, 2015 | 08:25 AM
  #176
Ecostang's Avatar
There's lots of inexpensive rear ends with 3.31 factory gears on eBay, in fact that's the easiest gearing to find. Midwaymustangparts is another good vendor with lots of used mustang parts.
Texas mile is legit for sure, I live in CO now but spent nearly my whole life in Texas. What's cool is that here in CO they have have hill climbs on curvy mountain roads you can pay to run. Recently I took the my Shelby to the central city hill climb, was a blast.
Old Aug 17, 2015 | 09:56 PM
  #177
Ecostang's Avatar
I didn't get anything done this weekend, I was at the street outlaws event in Oklahoma. It was a 10 hr drive and totally worth it, all the guys were incredibly nice and easy to talk to. We had a sweet spot reserved right beside the finish line.
Boosted gt signing my kids shirt, we got signatures from almost everyone.
Old Aug 17, 2015 | 09:58 PM
  #178
Ecostang's Avatar
I did get some stuff done today, turbo piping nearly completed.
Old Aug 17, 2015 | 10:00 PM
  #179
Ecostang's Avatar
I need to connect the 180 pipe to the throttle body
Old Aug 18, 2015 | 08:34 PM
  #180
Ecostang's Avatar
Got the 3" exhaust today, this should bolt up to my gt500 quad tips. I'll need a custom piece with cats installed to connect the x pipe to the ecoboost manifolds.
