Mustang 3.5L Ecoboost engine swap
#1361
Like Father...
I ♥ Sausage
I ♥ Sausage
Are they FRPP gears?
#1362
The ecostang on the other hand has much more than a whine, for a race car I could easily live with that. I would call this a howl instead that can be felt in the car, I was worried about tearing up the gears just on the short test drive.
He didn't check the pinion depth, we went with the same depth as the previous gears which I've read is usually fine. If that's the problem we have to start completely over.
#1364
More drama to go with all the other drama I've had getting wheels for this car, unbelievable.
One of my tires wouldn't hold air so I took it back to the tire shop for them to figure it out. The wheel is leaking around where the star meets the lip in several places as you can see. It will get swapped out under warranty, wouldn't expect such poor quality from weld.
3 steps forward 2 steps back......
#1365
Maier Racing (local to me) used to be sponsored by Weld. They told me they've gone through several regime changes recently, and a) quality and b) customer service have gone down the toilet.
#1366
Possibly some good news on the rearend. Before I tore it all down we rechecked the pinion nut toque with a higher quality tool than were using before... it's way too low. Supposed to be 20lb of free rotational torque and it's at 5.5lbs. It takes a huge ratchet to tighten it and Matt didn't have it with him today. After work tomorrow we will tighten the nut to spec and take it for another test drive.
I installed the aux injector controller here on the firewall.
#1368
How is this possible? Weld wheels are forged from a solid piece of
Aluminum. Could they have been machined that thin??
#1370
see below...3 peice
WELD Racing brings its application flexible racing technology to the street with a budget friendly 3-pc modular wheel using a unique welded assembly process. This wheel has the classic Weld Racing look and continues the Weld Racing tradition utilizing a forged billet center and cold forged rim shells. This unique wheel offers 3 mounting pad heights to clear specific drum and multi-piston opposed calipers.
#1373
see below...3 peice
#1374
Like Father...
I ♥ Sausage
I ♥ Sausage
#1375
Well I picked up the wheel and figured out what's going on. There's a bead of silicone caulking around the entire wheel lip where it's fused together inside. If there was one place that air can get under th caulking it would leak out of several places on the wheel face making it look like several leaks. I could probably fix this myself if I figured out where the breach in the silicone is, but the new wheel already shipped and I shouldn't have to fix things that are new
#1377
Well Matt came over today so we could tighten up the pinion nut, it didn't go well Before we could get it tight enough the end of the pinion sheared off.
The driveshaft flange wasn't even close to being pushed on all the way, this must have been a casting defect for this to happen. We really hadn't started getting it tight before it snapped off.
I'm going to use the old gear set out of my Shelby which is also a 3.31.
SO LAME
SO LAME
#1379
I was able to get a few other things done tonight. I added a return fuel port on the gt500 pump, getting it ready to go back in. I put a 45 inside the tank so gas doesn't drop back in to the basket. That might cause the pump to suck up an air bubble.
