Sponsored by:
Sponsored by:
Lowering Springs on a 5.0?
Old Aug 3, 2010 | 05:58 AM
  #81
GJM20115.0's Avatar
Originally Posted by shotzy
Here are some better pics of the FRPP 1inch drop. I am getting more impressed with the ride everyday as they are now settling in. I really think this is how the car should have come stock.
Do you think 0.5 inch spacers would help? I have the same wheels that I want to keep after I lower, but as it is now, about a 1 inch gap to the fender lip.
Old Aug 3, 2010 | 06:02 AM
  #82
shotzy's Avatar
Not sure. I have the full FRPP handling pack. Basically the suspension setup for dummies
I sure someone with more knowledge on the subject can help you out.
Old Aug 3, 2010 | 08:55 AM
  #83
Modshack's Avatar
Originally Posted by Minicobra
So are you going to cut the bumpstops then? or leave them stock height?
I need to run them a bit in varying road conditions to see if they become intrusive...So far I'm not hitting them, but I haven't played hard with the car yet..
Old Aug 3, 2010 | 12:35 PM
  #84
Freshmeat's Avatar
Originally Posted by Digital_Synapse
Eibach Sportlines with the new bumpstops they provide. I had the Pro-Kit on my last stang, and I wanted to go lower... this is lower, lol.
Oh young grasshopper. I own 2 sets of wheels, these stock 19's and the Bullitt Motorsport 20's, both have been on this car multiple times to compare ride at stock height and lowered, and I assure you, there is a large difference. You are failing to take into account rubber compounds associated with a performance 20" tire vs the stock tire. The rim diameter isn't the only thing changing, the rim width changed also, and with that the tire profile and make up are different. The 19x8.5 has a taller side wall and is more rounded of a profile from the contact patch when compared to a 20x10 wheel with a tire designed to keep the over all tire height the same +/-a few mm. The tire on the 20 has a shorter sidewall and goes straight up from the contact patch so ther is less meat in vertical as well as diagonal to absorb the impacts the road throws at it. Also, taller side walls with narrower contact patches have more give than a shorter sidewall with a larger contact patch. Think smashing a sphere vs smashing an oval of similar volumes both secured at points on the lateral ends, the sphere will have more vertical travel and spring vs the oval, but the oval will have less lateral travel. That's the point of getting wider and taller rims, to increase the amount of wheel that is metal, not rubber, to prevent flex under heavy driving, Like autoX, which 18s and 19s work, but 20's are too tall becaus they dont flex enough. Drag racing uses short rim height and wider wheels to allow tire flex and hook up on large contact patches. You need to think in 3d and take into account more variables than just 2d and one single variable changing, its not that simple. Again, I'm no professional at wheels/tires/suspension... but I used to be pretty **** good at Math, Physics, and Chemistry back in my college days. When I get home from work tomorrow I'll draw a pic and show you what I mean, it's kinda hard to describe.
I follow you quite well. My entertainment is based on more of an apples to apples comparison, stock contact patch to stock contact patch. By going wider in both wheel and tire selection, of course things change. My thought process is based on things being more in line from the 19" to the 20" as far as tire geometries, even with losing sidewall from the slightly larger wheels.
I have base 18s and nickel 19s; both sets are wrapped with stock Pirelli tires and the difference is negligible to say the least.
Old Aug 3, 2010 | 01:30 PM
  #85
nemosgt's Avatar
Originally Posted by Stinger1982
I will ask Gus when I speak to him tommorow.
I am sure they just forgot to list it.
Probably not.
None of the 05+ after-market struts (Koni, Tokico, etc.) fit the new 2011. That's why their Sports model doesn't mention shocks. Most springs seem to work okay though Eibach is developing 2011 specific springs as someone mentioned. I know as I speak from experience. Tried it already.
The new car uses different strut mounts/isolators and shorter struts. In order to install present after-market struts you will have to purchase 2010 strut mount/isolators and use these. If you want to use Steeda or MM adjustable camber plates, you apparently still need the 2010 or earlier spring isolators.
It's a pain being the first on your block, eh?
My first post here. Hope it sheds some light.
Cheers.
Old Aug 3, 2010 | 02:07 PM
  #86
nemosgt's Avatar
Sorry for the double quote above. Having a lot of trouble trying to post on this site for some reason. That was the fourth time composing that reply. The others were longer.
A few other points talked about on this thread:
Don't purchase a panhard bar until you finish lowering the car. You may find that the off-set is right on or close enough to make no nevermind. Save your money.
Yes, lowering will slightly increase the negative camber but this is not such a bad thing. with a mild drop you will probably be close to spec in any case. It will improve the look and stance of the car as well as improve the handling for only a small increase in tire wear. After a while you can invert the fronts left to right if the wear pattern bothers you. Camber bolts are a cheap fix if you really want to get back to original specs. But not if you track the car. The lower strut bolts that you replace have some issues in themselves and I would not replace these with the cheap camber bolts except as a DD only. Camber plates are a better solution but note the caveat about using the 2010 spring isolators on the 2011s in my previous post.
Can anyone explain why you would cut or remove bump stops if not required to? Lowering springs are shorter but are they not stiffer. I imagine that hitting the frame rail from an off-track excursion would be catastrophic to handling, not to mention body or frame damage.
Cheers.
Old Aug 3, 2010 | 03:43 PM
  #87
Digital_Synapse's Avatar
borrow someone's 20s for a weekend.
Old Aug 4, 2010 | 05:41 AM
  #88
crescent_wrench's Avatar
Cheers.
My 2010 didn't need a new panhard after lowering. It's centered. Don't know why, but it is. I understand its supposed to shift to the left. Maybe mine was actually a little to the right to begin with. Oh well.
Old Aug 4, 2010 | 01:36 PM
  #89
nemosgt's Avatar
Ford production tolerances!
Cheers.
Old Aug 4, 2010 | 02:35 PM
  #90
blk5.0's Avatar
"Do it right" well from what i was told by Sam is that they do not make struts for our car we have to use the 05-10 struts and shocks. He said you would have to buy the 05-10 strut mounts to make them work. Sams says" They'll fit, but you need either to do a little shimming on the front struts to work with 2011 mounts, or revert to older stock, or better yet, aftermarket mounts for them to actually work and not clunk."
So im confused on how the ones who have already put shocks and struts on the 5.0 how they did this.
How are people putting eibach springs on there car when a shop called for me today and said they are not ready for the 5.0 yet? do you have a part number i can use?
Old Aug 4, 2010 | 07:25 PM
  #91
Freshmeat's Avatar
Pff! 20s are WAY too big. It would look like crap.
(Please note the sarcasm.)
Old Aug 4, 2010 | 09:44 PM
  #92
lol tard
Road_Runner
Sep 2, 2024 04:46 PM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
GeoWett
Sep 30, 2015 06:40 AM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
