Notices
Boss 302 Side Exhaust Install/Discussion
Old 6/30/12, 05:32 PM
  #221
Overboost's Avatar
Originally Posted by 06GT
Downshifting to every stoplight now...
Pretty much.
I did turn the hardware around on the clamps so it was easier to access on the underside of the car.
Old 6/30/12, 05:57 PM
  #222
MyStang2010GB's Avatar
Originally Posted by MRGTX
Congrats!!!
No restrictors, right?
No restrictors!! I love downshifting so much more now...
Old 6/30/12, 06:20 PM
  #223
06GT's Avatar
Pretty much.
Very good idea. I tightened up Capt' Distraction's using some vise grips
Old 7/1/12, 08:41 PM
  #224
Overboost's Avatar
Well, here's my suggestions/how-to for those of you doing the install:
1 - 13 & 15mm 1/2" drive sockets and ratchet wrenches are your friends. Get them ready. A second set of hands is a big help.
2 - before you tear the stock exhaust off, remove the splash guards from each side ((3) x 13mm, (2) nuts, (1) bolt).
3 - Disconnect your over axle pipes from the axle backs. This way, once the new H-pipe is in place, you can realign everything. Once the new H-pipe is in, have someone else push the over axle pipes in and tighten down the sleeves. Last, connect the axle back portions and line everything up.
4 - The side pipes are all 15mm. After I got the H-pipe attached to the upstream side, I mocked these up and started all the fasteners on them. Once I got them all aligned, I tightened it all up.
5 - The clamps that attach at the front of the H-pipe need tweaking to make your life easier. Take the bolts out and flip them so the bolt heads are facing the ground, not the body. You'll have a much easier time tightening the whole thing down.
Anyone have the Roush side splitters and this exhaust and run into problems? When I was at the local cruise last night, I noticed a lot of heat pouring up the side of the car. I still can't get over how good it sounds. I should have ordered this right after it came out. The combo with the S-Types out back is just great.
Old 7/4/12, 03:43 PM
  #225
Boomer's Avatar
I really hate you guys right now...you know that right....
Old 7/4/12, 04:01 PM
  #226
Overboost's Avatar
Stop slackin and buy the one for your car already...
Old 7/4/12, 06:58 PM
  #227
Boomer's Avatar
She 'spensive man!
Not to sound cheap, but I'm waiting on the other thread to find out how Sean did with the existing exhaust.
If the side pipes and hardware can save me spending 2-300, might be worth it.
Then again, who knows how much a shop is going to charge for putting it in and modifying the existing FRPP XPipe.
Old 7/4/12, 07:32 PM
  #228
Overboost's Avatar
She 'spensive man!
Other thread?
Old 7/4/12, 08:23 PM
  #229
Boomer's Avatar
4.6 on the 05-09 section
https://themustangsource.com/f669/fr...st-kit-509159/
Old 7/5/12, 05:35 AM
  #230
Overboost's Avatar
The 11+ kit is $699, and the 05-10 kit is $649. For what he's paying to get the side pipes, it seems to make more sense to buy the whole kit and sell your current setup. I priced out the components before it was available and its close to what they sell it for through some retailers.
Old 7/5/12, 05:58 AM
  #231
SeanD's Avatar
For us 3V peeps that are not running stock headers, paying $649 for the kit is just dumb. I am not about to buy the kit and then have a useless X-pipe in my possession, that I now have to try and sell. Just doesn't make sense. I paid $492 for the Ford parts and another $60 for a stainless steel J-pipe (for the connectors) and I have exactly what I need to get the job done. The 3V kit is not a bolt up like it is for you Coyote people. There still is alot of work needed to get it installed. I have yet to see a FRPP installation document that describes how to install the kit, since the side pipes don't have anywhere to mount on a 05-09.
Old 7/5/12, 06:30 AM
  #232
Boomer's Avatar
Never thought about that.
Curious as to how it bolts up then.
Old 7/5/12, 06:39 AM
  #233
SeanD's Avatar
Me too. I wish FRPP would release the document so that I could see how they bolt it up. On mine, I am going to have to mimic the 11-13 setup and get a hole drilled into the frame and have a nut welded in, so that the factory bolt can secure the pipes to the frame. I do not see any other way of it working.
Old 7/5/12, 09:27 AM
  #234
Overboost's Avatar
I didn't realize it was only compatible with the 2010 cars. BFR lists it as compatible with 05-10s, but the FRPP site does not.
Old 7/5/12, 10:05 AM
  #235
Boomer's Avatar
I know, that's what I'm trying to find out.
All the other sites that list it for sale, say 2005-2010.
Wonder what it would require.
Old 7/5/12, 10:08 AM
  #236
Tony Alonso's Avatar
That X-pipe is was caused me to say "bummer". I'd rather have the side pipes adapted to the stock H configuration.
Old 7/7/12, 10:23 AM
  #237
Tob*'s Avatar
I want to say that when FRPP first advertised the 4.6 3V kit (M-5220-3VMB) that there was mention of it fitting model years '05-'10 but has now been changed such that the listing only shows fitment on '10 models. This is somewhat disconcerting as it shows that somebody at FRPP isn't up to speed on the relevant changes made to these cars over the years. The issue obviously came up and FRPP moved to correct it. As such, I believe that FRPP vendors are still listing the part as originally released by FRPP and that's why (for example) you see that Buyfordracing lists it as encompassing a bigger list of model years to fit than FRPP now lists on their own site.
The issue at hand is the attachment point on the chassis that allows fastening the end of each sidepipe is not in place in certain model years. Curious as to when Ford started to include the necessary chassis point I was basically told the following from someone in a position to correctly answer my question...
Revised convertible v-braces went in in late 2010. That's when the weld nut was added
There were actually two welded nuts added on the rocker and you can see them in the following photo both atop and below the oblong or oval hole that are used to sandwich the plate that Ford welds to the square tube bracing.
____________2011GT500ragtopbracewhereBossquadneedstobe-1.jpg?t=1336836331
If you look at the following photo of my '09 chassis you'll see that neither of those two holes exist.
IMG_8878.jpg?t=1317942572
The '12/'13 Boss makes use of the rearmost threaded hole for attachment.
Boss.jpg?t=1317945599
My solution, one that would allow fitting the Boss sidepipes to my 2009 GT500, was to drill a hole in the appropriate area, slip a somewhat 'rounded' nut down through the top, and then weld the nut in place. To illustrate...
I first drilled the necessary hole, checking fitment through the bottom of the hole (note that I had knocked down the high points of the nut to allow it to fit within the round hole).
IMG_8955.jpg?t=1318204196
IMG_8947.jpg?t=1318203957
IMG_8952.jpg?t=1318203999
Once I had a nice tight fit, I slipped the nut up through the oval hole and then down through the hole I had drilled.
IMG_8957.jpg?t=1318204210
Then I broke out the MIG for a few minutes.
IMG_8959.jpg?t=1318204492
IMG_8965.jpg?t=1318205641
IMG_8967.jpg?t=1318205771
After some Vista Blue spray had setup, I could then attach the sidepipes to my '09.
IMG_9037.jpg?t=1318798310
So when I saw that FRPP was releasing a kit that included fitting the Boss pipes to S197 chassis vehicles that didn't come with the requisite in-chassis fasteners, my interest immediately piqued. I searched for a set of pdf directions as well, looking for whatever solution FRPP had come up with that would allow a bolt-on for early chassis cars.
Looks like FRPP doesn't have one (or at least yet anyway).
I think I could come up with a no-drill solution and am surprised that FRPP didn't. A plate assembly that would slip up and bolt through the oval hole, with a cantilevered extension that runs aft to the needed nut/bolt location. I'd invert a stud or bolt so that the sidepipe could be drawn up tight to the rocker, as OE, only now with a nut instead of a bolt.
If FRPP can't make it happen and anyone here needs something get a hold of me. We'll get it to work. Hope this clarifies the issue.
Tob
Old 7/22/12, 10:18 AM
  #238
samterry1234's Avatar
Originally Posted by Big Papi's Pony
We will officially have 2 Yellow Blaze GTs with quad exhaust on the forum!
You won't regret it. DO NOT put the restrictor plates in. Run them wide open!
better make that three. I just purchased as well eagerly waiting them to be dropped off
Old 7/22/12, 10:50 AM
  #239
Overboost's Avatar
Honestly, this with the Borla S types out back is like Zeus' angry gurgling. It's addictive to stay on the pedal everywhere you go.
Old 7/23/12, 11:59 AM
  #240
FastRedPonyCar's Avatar
Anyone considered the side exhaust alternative from Stainless Works? It's about $250 cheaper.
http://www.pfyc.com/MU5022.html
Quick Reply: Boss 302 Side Exhaust Install/Discussion
