Sponsored by:
Sponsored by:
2 Issues: Oil leak and how to remove o2 sensors
Old Oct 5, 2012 | 02:54 PM
CaptDistraction's Avatar
1st, the easy one (lol): what tool do you use to extract the front o2 sensors? I couldn't figure out a straight wrench combination that got the job done, the placement of the sensors makes it difficult to get enough torque to break them free without rounding edges, etc.
2nd:
The back of my moroso oilpan stays wet, not a ton of oil, but enough to be a nusiance. It looks like 1 of 2 possibilities, its seeping from nearby threaded sections (I did use sealing tape) for the drain and temp sensors and working its way back up the pan, or, its a problem up at the top seeping down (seems more likely....possibly rear main seal?)
If its the rear main seal, I assume my only option is to pull the transmission? IF so, what am I looking at in hours roughly (I've pulled the motor in 4, but never dealt with the transmission side of this car). Also, what is my best bet in getting that thing out? standard jack will do or do I need a lift and specialized tools?
Old Oct 9, 2012 | 09:18 PM
06GT's Avatar
**** dude you just can't catch a break
Old Oct 10, 2012 | 12:34 AM
At least I can install that ford racing timing ring I guess
Old Oct 10, 2012 | 06:07 PM
autozone has the free loaner wrench to remove the 02 sensors. Why do you want to remove them??
Old Oct 10, 2012 | 06:11 PM
Resolution78's Avatar
It's a socket made for o2 sensors has a slit in it for the wire
Old Oct 10, 2012 | 08:42 PM
I was using the ones that originally were installed in the car, had 35k on them and were on there when the original motor let go.
Some readings were off and it was decided that it was best to install fresh sensors to ensure clean datalogs.
I was able to get them cleared with a crows foot socket, but it still wasn't any fun, Ford had them seized in there fairly well. I put the new ones in at half the torque.
Old Oct 11, 2012 | 06:01 PM
06GT's Avatar
Only 5.5ty ft lbs this time? Good call on installing the pulse ring. Changing my diff fluid this weekend, fun times
Gill5oh
Oct 6, 2017 10:50 PM
trackpack13gt
Jul 25, 2017 05:29 PM
09-gt/cs
Oct 15, 2015 10:03 AM
southern stang
Sep 26, 2015 04:19 PM
